(searched) p1259 quick question
Old Jan 3, 2009 | 08:12 PM
2k_Si's Avatar
Default (searched) p1259 quick question
i have a few codes and taking care of them 1 by 1. the one im on is p1259. which is vtec malfuction. i also have 2 bad o2 sensors. im running a gutted cat. im converting to obd1 to eliminate my 2nd o2, and replacing my primary 02. my question is would my bad 02 sensors cause me to throw the p1259 code ,or should i replace my vtec solenoid? i already checked the filter , and and the movement of the valve inside.
Old Jan 4, 2009 | 07:38 AM
2k_Si's Avatar
Default Re: (searched) p1259 quick question
Bump
Old Jan 4, 2009 | 07:41 AM
andoxviii's Avatar
Just fix all of the easy stuff first (like O2 sensors), and you may have other codes disappear. As for that particular code, I have no idea...
Old Jan 4, 2009 | 07:55 AM
nub's Avatar
nub
vtec malfunction is pretty unspecific. You may want to try this https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/ so you can find your problem
Old Jan 12, 2009 | 07:05 PM
lee0149's Avatar
Originally Posted by nub
vtec malfunction is pretty unspecific. You may want to try this https://honda-tech.com/forums/showthread.php?t=1901557 so you can find your problem
??????he already know that its p1259???????
will simple one check oil level i guess.
Nos651
19
Jul 5, 2014 03:34 PM
SweetDA9_TR
11
Apr 23, 2009 04:33 PM
CTR-GSR
Mar 13, 2007 03:18 PM
MysteryWagon
Mar 10, 2005 08:07 PM
JDM-SHREK
Nov 8, 2004 07:36 PM
