(searched) p1259 quick question
i have a few codes and taking care of them 1 by 1. the one im on is p1259. which is vtec malfuction. i also have 2 bad o2 sensors. im running a gutted cat. im converting to obd1 to eliminate my 2nd o2, and replacing my primary 02. my question is would my bad 02 sensors cause me to throw the p1259 code ,or should i replace my vtec solenoid? i already checked the filter , and and the movement of the valve inside.
Re: (searched) p1259 quick question
vtec malfunction is pretty unspecific. You may want to try this https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/ so you can find your problem
vtec malfunction is pretty unspecific. You may want to try this https://honda-tech.com/forums/showthread.php?t=1901557 so you can find your problem
??????he already know that its p1259???????
will simple one check oil level i guess.
CTR-GSR
03-13-2007 03:18 PM
MysteryWagon
03-10-2005 08:07 PM
