EM1 - CEL went on again...
Old Jan 3, 2009 | 02:15 PM
DeathLens's Avatar
Default EM1 - CEL went on again...
I just got this code!... again! I'm really sick of this... I've replaced my sensors many times and just put in a new cat
P0133 Circuit Slow Response Bank 1 Sensor 1
P0420 Catalyst System Efficiency Below Threshold
I have bosch sensors, up and down stream and an aftermarket cat, and I/H/E.
Old Jan 3, 2009 | 02:27 PM
Da4yoA$$'s Avatar
Default Re: EM1 - CEL went on again...
You need cel elim...Mine did the same thing same codes...with cel fix it puts the secondary o2 sensor in position so it doesnt read the same as the bank 1 sensor thus making the cel light come on...Hope this helps..
Old Jan 3, 2009 | 03:06 PM
Da4yoA$$'s Avatar
Not sure about emissions..but with the cel light off I dont see why not...Should only need one on the secondary 02 sensor thats in the cat...Good Luck..
Old Jan 3, 2009 | 03:09 PM
DeathLens's Avatar
Thanks! I'm gonna buy one of those now.
Old Jan 3, 2009 | 08:41 PM
2k_Si's Avatar
you should find out why your 02 sensors and cat went bad in the first place. IMO
Old Jan 4, 2009 | 08:27 AM
The_Honda_Guy's Avatar
Yea, Bosch = garbage. If you wanna save some money you can get the NGK replacement oxygen sensors. I've tried these on my RX-7 and they worked great with no issues.
Old Jan 4, 2009 | 10:45 AM
Da4yoA$$'s Avatar
oe style are good..Thats what i replaced mine with...
Old Jan 4, 2009 | 11:05 AM
Da4yoA$$'s Avatar
Why is it broiled..Cause thats probally part of the problem...you can get a high flow cat from many places or test pipe and replace sensors and add the cel elim and all your problems will be gone....but you need to figure out why its broiled if you dont know..cause if you dont fix that problem its gonna ruin your sensors again and you will be right back in the same position in a month...
HAZARD_1310
Apr 23, 2008 05:29 PM
junkspeedproject
Feb 5, 2008 01:44 PM
3rdgenLS
Mar 14, 2005 02:21 PM
Nero2007
11
Jul 28, 2004 04:22 PM
ajchen
Mar 26, 2003 08:23 AM
