HALP! i think i fried my ECU AND tranny controller! non-working car
Old Dec 20, 2008 | 07:18 PM
361 accord's Avatar
Icon3 HALP! i think i fried my ECU AND tranny controller! non-working car
VITAL INFO:
2000 accord sedan, F23A1 automatic, EX-Leather
i have a multimeter, so probing stuff is an option
ok, so here is my wack *** situation, somehow, my engine will crank over and run.. but the tach doesnt work and i can not shift out of park, and the little lights on the cluster for PRND21 do not light up
so i used the shift lock override thingy and it slams into gear!
i drove it around my block and i think i only have first gear, also the speedometer did not work
i tried pulling the battery, and pulling the clock light to reset the ecu,
no worky, still is RETARDED
ok also, weird as hell
my power mirrors and power seats work as well as all the lights and the horn and radio and keyless entry and trunk release
but NONE of the power glass works not even the sunroof
ok and i checked the power windows- fuse the one under the hood, it is NOT blown, i even probed the fuse for continuity with my multimeter
Old Dec 20, 2008 | 07:46 PM
02 accord's Avatar
You're RETARDED for pullin the clock light to reset the ECU. Try pulling the clock fuse.
As for the shifter interlock, the ECU needs to see the shifter in P (which it doesn't) before it activates the interlock, so it makes sense that it doesn't work for you.
Old Dec 20, 2008 | 07:48 PM
361 accord's Avatar
i meant to say clock fuse
Old Dec 20, 2008 | 09:06 PM
361 accord's Avatar
so i checked the ECU, and it is plugged in tight, and so far i have not founfd a single burnt fuse
WHAT DA ***
Old Dec 21, 2008 | 12:10 PM
361 accord's Avatar
Default Re: gauges, power windows dont work, cant shift out of park, but....omgwtfbbq
BUMP DAMMET MY CAR DOES NOT WORK, its a gigantic hunk of metal taking up room in my garage!
Old Dec 22, 2008 | 06:41 AM
Duane_in_Japan's Avatar
Default Re: HALP! i think i fried my ECU AND tranny controller! non-working car
The first thing you need to do is spend a little money on a wire diagram since no one has offered one for you here yet, post it here to the site and then many people will help you read it and tell you what to test.
I say start with the bigger fuses, one big fuse will control many smaller fuses, so this means that there are at least two fuses protecting most circuits. Also there are probably two circuits powering up half and half of the systems on the car so it may be possible that part of the ignition switch may be bad.
We will need a complete list of what does not work, you may have already done that but please be sure, this will help in breaking down the wire diagram.
Old Dec 22, 2008 | 06:50 AM
Did a little research, Fuse 51 underhood, 40 amp, controls the power windows and sunroof. Will wait for complete list or confirmation of complete list completed previously.
Old Dec 22, 2008 | 07:04 AM
GhostAccord's Avatar
Lets see... tach doesn't work and you are unable to shift. That too me points more towards the Vehicle Speed Sensor (VSS) or Transmision Control Unit (TCU).
Is the D4 light or CEL on or have you lost all cluster power?
What have you done lately to the car, anything electrical, a new stereo, aftermarket alarm system or install a remote srtarter?
Old Dec 22, 2008 | 01:44 PM
361 accord's Avatar
umm i fixed it, it was a god damn 7.5A fuse for the back up light/instrument light
no friggin idea why that would affect my power windows though :wtf:
cuz at first i checked all the fuses that seemed important, like ecu and power window fuses and under the hood, all were fine then i said **** it and started checking random ****, sure enough found one blown and replaced it, then reset ecu via pullin clock back up fuse, and BAM, fixed
btw i havent done jack **** to my wiring because i am askurred of wiring issues! factory EVERYTHING,. only electical stuff i have done is replace my courtesy lights, map lights and dome light with direct replacement LEDs
Gking97
Apr 17, 2017 01:15 PM
jtbob24
Honda Civic (2001 - 2005)
Jan 14, 2015 09:20 PM
scarcha
Jan 16, 2011 12:35 AM
mr_gs-r
Feb 23, 2007 06:44 AM
BoostedH23a1
Mar 18, 2003 06:24 AM
