eg CEL and cutting out
Old Dec 19, 2008 | 05:14 AM
slob20ef's Avatar
Default eg CEL and cutting out
ok,
If i am driving down the highway at a little over 80 which is around 4k rpm, the car will cut out for a second and then through a check engine light, when its thowing this the car runs supper supper rich and wont rev past 4200, sounds like my 2step. If i drive for a while it will go away for like five minutes and then come back on. Also some times when it comes on, if i shut my car off and start it back up, the check engine light goes off and the car runs fine, like i said for about 5 or ten mins. I have been told this could be a main relay? or even something in the ignition? Im so stumped and really need to figure this out. Thanks?
Old Dec 19, 2008 | 05:57 AM
z6hatchboy's Avatar
go to the sticky and check your cel, its probably a sensor: map,tps
Old Dec 19, 2008 | 08:15 AM
slob20ef's Avatar
I know its not map or tps.
where is the sticky located?
thanks
Old Dec 19, 2008 | 09:01 AM
z6hatchboy's Avatar
its should be at the top of this (92-00) forum, says something like NEW how to check cel or somthing like that
bad71chevy
May 19, 2013 05:23 PM
19cIvIc94
Jan 21, 2009 10:31 AM
dapek
Dec 1, 2008 09:38 PM
CRXified
Jul 30, 2005 01:31 PM
743 Stunna
Dec 20, 2004 05:04 PM
