need some wiring help
Old Dec 18, 2008 | 10:19 PM
iwanttokillgod's Avatar
Default need some wiring help
trying to wire the egr and secondary butterflies into my 93 del sol si i have the ecu pin out there is no problem there. the question i have is there is three wire coming off the egr valve but i dont know which wire goes to what pin out. the 3 wire clip that im using is not the stock 3 wire clip for a egr valve so color wont match. need help with wire position also for the secondary butterflies its a two wire plug how do you know what wire goes to what pin out or does it even matter
Old Dec 19, 2008 | 06:01 AM
z6hatchboy's Avatar
what are you doing, a h22 or b18 swap?
Old Dec 19, 2008 | 08:36 AM
h22
Old Dec 19, 2008 | 08:57 AM
z6hatchboy's Avatar
dang, i had that somewhere on my old comp for my h swap. try this though, if this doesnt help search yahoo or google https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/ . i usually search yahoo for whatever and put honda tech after what im searching for
Old Dec 19, 2008 | 10:51 AM
that dosent help because it tells u the pin out on the ecu but you dont know what wire goes to what pinout from the sensor
Old Dec 19, 2008 | 04:05 PM
up
Old Dec 19, 2008 | 04:10 PM
z6hatchboy's Avatar
i just got home, kinda checking things real quick then leaving. But, go to pdftown.com (maybe net cant remember) and download the prelude service manual (for your generation motor probly 93-97) and civic service manual (if you need it), all wire diagrams are in there for the sensors and everything. thats what i use when i cant find it on here.
Old Dec 19, 2008 | 08:24 PM
thanks
halfkoreanboy
Nov 2, 2010 11:15 AM
redman223
Jun 26, 2003 06:52 PM
43MA
Feb 16, 2003 08:46 AM
Pro-Lude
Aug 22, 2001 08:41 PM
