95 honda civic ex cluster problems
what causes the speedometer(mph) not to work? it only happen to me this winter so far. although sometimes it'll jump up and down too. any suggestions what might cause that?
If CEL is on, check the CEL FIRST!!
If the CEL pertains to the speedo sensor, ding ding ding, it's probably just the sensor located ontop of the transmission.
If CEL is NOT on....
Problem: The speedo doesn't work but the odometer works.
Solution: Replace the cluster or just replace the speedo gauge
Problem: The speedo doesn't work AND the odometer doesn't work.
Solution 1*: Bad Sensor - Replace the speedo sensor in the transmission.
*CEL should be on
Solution 2: Bad Gauge - Replace cluster or just replace the speedo gauge
IF Neither solution above fixed it.
Solution 3: Check all wiring from the sensor to the gauge. Because the signal is disrupted somewhere.
*CEL should be on
hondaboi7
Mar 18, 2009 09:06 PM
luder916
Dec 17, 2008 07:57 PM
