cluster needles
Old Dec 17, 2008 | 02:45 PM
darkwater_ghost's Avatar
Default cluster needles
ok so I redesigned my cluster gauge faces, how can I adjust the needles? my speed isn't right. and for the rest I have to replace from the junkyard. not a project I can say I will ever do again.
I took the needle off and put it on at a little less than zero and when I start to go I go about 20mph before It starts to move then after that it seems about 10mph off.
its a 97 ex cluster.
please help.
Old Dec 17, 2008 | 05:27 PM
bump
Old Dec 18, 2008 | 01:51 PM
bump, anyone ever have this problem?
Old Dec 18, 2008 | 02:33 PM
SOHC_civic_si's Avatar
I've had this problem before with my speedo and tach. What I did has take the speedo needle off when my car was running then put it back on at 0. Then I had a friend drive along side me and tell me what speed he was going to match mine.
Old Dec 20, 2008 | 06:39 PM
ok I got every thing working but my temp is backwards when I turn the car off it goes to hot instead of down. does anyone know what the problem is? I thought maybe the fuel and temp got mixed up but there is no way to put them in the wrong places. I searched but the only matching problem never got answered.
Old Dec 20, 2008 | 11:35 PM
Skunk.Werks's Avatar
needles aren't meant to be removed from the gauges, they are carefully calibrated from the factory and you won't be able to fix them whatever you do, you ****ed up...Get a new cluster
Old Dec 21, 2008 | 09:28 AM
kp's Avatar
kp
Default Re: cluster needles
Amen.
Old Dec 21, 2008 | 12:54 PM
can anyone tell me why my temp and fuel are working backwards?
Old Dec 21, 2008 | 01:13 PM
shiux's Avatar
because you tampered with OEM perfection. get a new cluster.
blinger
11
Mar 26, 2024 08:08 PM
demonicivis1320
13
Sep 26, 2011 08:26 PM
UKej1
Jan 8, 2007 07:15 AM
rev210k
Jan 31, 2006 05:19 PM
