Can I Turbo An All Motor Built Poor Man's R?
Ok I just got an 94 EG hatch with a poor mans R. I dont like the idea of All Motor so I was wondering if I could boost that engine and maybe stay on low boost since the CR is so high. It has a semi built Bottom End. JE 12:1 Pistons with stock GSR rods. Has ARP rod bolts. B16A head, SKunk2 cam gears, Greddy timing belt, B16 transmission,Exedy clutch, DC header. Just wondering with that high of a compression ratio could I even boost at all?
you can boost it but it wont be too reliable. nowadays its all in the tune though so find a good tuner and see what they recommend. id try and get the compression down to 10:1 or lower and get some forged rods and you can turn the boost up.
hahaitzsteven
Jan 9, 2005 06:09 PM
