throttle stays open
Old Dec 4, 2008 | 11:58 AM
fatpride111's Avatar
Default throttle stays open
been having problems with my gsr, and lately when i took it out to see if it was running right, i floored it, reved it to about 7k, and let go of the gas, but the revs didnt drop past 4,5k. but it only does it while im moving. i did it today in neutral and it dropped fine.
it stayed there, so i disengaged the clutch, turned off the engine (while still moving), turned it back on, and it was still doing it. i played around with the pedal, and it would rev fine, but wouldnt drop. i left it alone, and tried driving it back home while the car reving at 4,5k, and finally it just dropped back to normal.
drives just fine, but if i floor it, and it revs past 5k, it'll stick.
i checked if there were any vaccum leaks around the intake manifold, and it looked fine. throttle cable looks fine.
Old Dec 4, 2008 | 12:02 PM
Jas9848's Avatar
check the throttle plate for carbon build-up. it may be sticking open. also check the spring on the throttle body where the cable attaches too-it should snap back quickly when you open it all the way and let it go.
Old Dec 4, 2008 | 12:41 PM
mouab18c1's Avatar
your tb cable could be bent..
Old Dec 4, 2008 | 12:57 PM
sivik_outkast's Avatar
x2 Definitely clean out your throttle body. Mess around with your throttle cable as well and listen for changes in rpm.
Old Dec 4, 2008 | 01:08 PM
red_crx's Avatar
all of the above or you cable is too tight....I had the same problem last week.
Old Dec 4, 2008 | 01:49 PM
cleaned the TB last week while i was messing around with the idle (had a bad idleing problem), and i'll have to check the cable. i replaced my last one cause it bent, and this one is about a month old.
my throttle return spring looks good. i was playing around with it, and it snaps back good.
is there any chance a bad TPS, or something electrical that could cause this? i have a very small idling problem still, it jumps from like 900rpm, to like 1,1krpm, so maybe these 2 are related?
Old Dec 4, 2008 | 01:54 PM
B18CUL8R's Avatar
do you have a short ram intake?
this might sound silly but my friends tb got stuck open one time. we were like wtf?
we took off the intake pipe to see a metal cap from the underside of the intake filter wedged in the throttle body. luckily it was too big to go through the throttle body.
Old Dec 5, 2008 | 05:57 AM
metal cap? i do have a short ram, but i have no idea what metal cap under the filter youre talking about... sorry man. ill take off the intake pipe just in case though.
JDMarkLangston
Apr 25, 2013 07:35 PM
mkazm83
Jul 5, 2007 08:47 PM
killer hatch
Mar 19, 2007 01:29 PM
mr poo
15
Jun 14, 2006 08:09 PM
frostcivic
Oct 12, 2004 03:52 AM
