axle ?
Old Dec 1, 2008 | 01:50 PM
ill fast's Avatar
Default axle ?
Is it possible to take apart the axles? if what is involved in doing so? thanks
Old Dec 1, 2008 | 09:01 PM
EFRue57's Avatar
yes, remove the metal clamp, take off the boot, remove bearings. that's really all there is to it
Old Dec 1, 2008 | 09:05 PM
97GSRTeggy's Avatar
PITA to put back together though. well kinda
Old Dec 1, 2008 | 09:53 PM
94DB8's Avatar
get ready to be extremely greasy ... and ya bro its a PITA to put back together
you have to line up the bearing a certain way (they're rectangular, put them horizontal) iirc
Old Dec 1, 2008 | 11:18 PM
ill fast's Avatar
so there is no pins to remove
Old Dec 2, 2008 | 08:39 AM
97GSRTeggy's Avatar
Just go to like orileys or somewhere pay 40 bucks for some with life time warranty. Itll be easier.
Old Dec 2, 2008 | 11:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Inner joint is rebuildable/serviceable. Outer joint is not serviceable.
Old Dec 2, 2008 | 01:15 PM
tweek_boii's Avatar
No picutre necessary, really simple. What are your intentions ?
Old Dec 2, 2008 | 09:33 PM
ill fast's Avatar
to reapply the grease when i add a new boot this weekend
Old Dec 2, 2008 | 11:59 PM
PandaSJ's Avatar
I don't think you need to take apart the whole axle do you?
Old Dec 3, 2008 | 05:33 AM
Community Builder
You do unless you use those POS split-boot replacements.
To take apart the axle, you cut the band clamps, remove the inner joint cup, remove the inner tripod w/ bearings (don't lose them), remove the inner boot, and then slide the outer boot down along the shaft to remove it.
Then you slide a new outer boot up the shaft, pack with grease, then cover the outer joint and install new boot clamps. Slide on a new inner boot, install the tripod w/ bearings, pack the inner boot with grease, and then slide on the outer joint cup, and clamp the inner boot in place.
You have to make sure to adjust the axle length before clamping the inner boot over the axle shaft. That small clamp on the inner boot is what determines the at-rest length of the axle. If you clamp it too far down the shaft, it will be too short and the inner boot will be over-extended when installed and could possibly rip apart.
Old Dec 3, 2008 | 01:34 PM
ill fast's Avatar
what should the length be set at? one last question. how can you tell which axle is bad?
Old Dec 4, 2008 | 06:54 AM
Community Builder
Not sure on the length. The Helms manual lists the correct length. A bad axle will usually have a slight amount of freeplay in one or both joints.
Old Dec 4, 2008 | 05:11 PM
ill fast's Avatar
in which direction will there be play
Old Dec 4, 2008 | 06:32 PM
Community Builder
The outer joint should be able to bend only, and not move axially at all. The inner joint mainly moves axially, and can bend slightly (but not much). Neither joint should have ANY rotational freeplay whatsoever. That means if you grab one of the joints and try to turn it (as if you were spinning one of the wheels) there should be no movement apart from the wheel itself moving.
Old Dec 4, 2008 | 08:27 PM
ill fast's Avatar
ok that clears up alot. tomorrow ill check to see which axle is bad on my car
Old Dec 5, 2008 | 06:14 AM
Community Builder
With the axle installed on the car, you should be able to move any part of the axle at all, aside from the movement when turning the wheel. The normal axle joint movement I mentioned above refers to when the axle is removed the car.
civicman420
Dec 14, 2009 05:50 PM
hardvtec90
Sep 21, 2008 07:51 PM
CRX_Control
Apr 7, 2006 07:30 PM
mums_car
Jul 11, 2004 10:44 PM
TeginRAGE
Jul 17, 2001 06:17 AM
