cluster problem.
Old Dec 1, 2008 | 11:00 AM
projectr's Avatar
Default cluster problem.
my cluster on my eg used to work but over the weekend it was flickering and just stop working.speedo,tach,gas and temp works but the back light just shut down.what could it be.i checked fuses and they are good.can anyone help me out
thanks
Old Dec 1, 2008 | 01:42 PM
wrenchez81's Avatar
loose wire @ the connector??? fudged up printed circuit in ip???
Old Dec 1, 2008 | 02:00 PM
projectr's Avatar
so should i check the back of the cluster.make sure the plugs didnt get messed up
Old Dec 1, 2008 | 02:36 PM
wrenchez81's Avatar
thats a start..
Old Dec 1, 2008 | 04:12 PM
instrument's Avatar
ever remove your cluster? its not too hard.
just use a screw driver and make sure you get the screw hidden behind the clock.
make sure all the connections are tight, have you removed your radio lately?
i'd also check the fuses if you havent.
Old Dec 2, 2008 | 10:54 AM
projectr's Avatar
check fuses...good.
i havent moved the radio for a few months.
Old Dec 2, 2008 | 11:00 AM
mikehawk's Avatar
mine is jacked too .. my climate control lights work but my gauge lights etc do not lol sucks driving at night i've tried using diff clusters, replacing blubs, fuses .. i checked my wires/plugs with a multi meter .. and they have 2 + connections and no - so its not getting a ground .. or something idk how to fix it unless i rewire the entire thing.
Old Dec 2, 2008 | 02:06 PM
jeremyrocksursox's Avatar
thanks
did you check the actual bulb? doesn't look like you did
Old Dec 2, 2008 | 06:47 PM
G's_civic's Avatar
TRIAL USER
what about the dimmer switch? check that
my ek did the same thing and its a pain to drive at night
...k20...
Jan 5, 2012 12:22 PM
khurrum
Jan 29, 2008 02:23 AM
EJay1
10
Feb 2, 2006 08:24 PM
yeegsr
Jun 28, 2005 10:40 PM
Sliced Beard
Aug 28, 2004 03:03 PM
