Cluster doesn't work.
Old Dec 29, 2011 | 12:29 PM
...k20...'s Avatar
Default Cluster doesn't work.
I have a 96' accord manual trans 2 dr. The cluster just sticks at 20 any idea what is wrong with it? I also changed it already for another one and just keeps sticking at 20.
Old Dec 29, 2011 | 07:56 PM
bandit67's Avatar
Default Re: Cluster doesn't work.
If the vss is working, check by seeing if the cruse control works, it is probably the circuit board inside the speedometer. See the FAQ section as to how to change it out. Mine was doing the same thing and it turned out that the screws that held in the circuit board was loose.
Old Dec 30, 2011 | 07:01 AM
...k20...'s Avatar
Thanks ill check it out.
Old Dec 31, 2011 | 07:03 AM
...k20...'s Avatar
so basically after i remove the white plastic just tight up the screws on the circuit board?
Old Jan 1, 2012 | 06:14 PM
75aces's Avatar
Did you take components out of the new cluster? Check all connectors and screws.
Old Jan 3, 2012 | 08:13 AM
...k20...'s Avatar
Well I took the cluster out checked all the wiring tightened all the screws and put everything back together. It works but then it starts sticking at 20 again. So it works off and on. Anything else i could do? Maybe just get another cluster?
Old Jan 5, 2012 | 06:16 AM
bandit67's Avatar
Following the posted FAQ, once you remove the clear lens, by releaseing the seven tabs, removing the four small screws will let the whole center MPH section fall out. You can then replace the circuit board only, or center section, or if you have the exact same cluster and do not care what number of miles it has, replace the whole cluster .....
Old Jan 5, 2012 | 12:22 PM
...k20...'s Avatar
I had an extra cluster from my last accord and i just switched out the mph section and it worked.
thisiskev
May 3, 2010 05:10 AM
projectr
Dec 2, 2008 06:47 PM
R015
May 30, 2008 01:20 PM
Sliced Beard
Aug 28, 2004 03:03 PM
bgod
Dec 17, 2002 10:53 AM
