what is a code 23???
Old Nov 28, 2008 | 10:51 PM
cadwiese's Avatar
Default what is a code 23???
i have a 95 b18 swap in my eg and the ref said that i have a code 23 and that i need to clear it then go back for a retest. can anyone help???
ty
jw
Old Nov 28, 2008 | 11:17 PM
rsxtj's Avatar
Banned
KS (Knock Sensor) ujust put some p28 ecu and they will kome off the check light
Old Nov 29, 2008 | 10:40 PM
cadwiese's Avatar
it does not have a cel. the guy said the code is stuck in the computer. the engine is from kapan could that be why it maybe doesnt have a knock sensor in it?
Old Nov 29, 2008 | 11:41 PM
rsxtj's Avatar
Banned
aif you are using a p72 eci this one need knock sensor
Old Dec 1, 2008 | 11:32 AM
cadwiese's Avatar
i am running a p75 ecu
Old Dec 2, 2008 | 10:45 AM
cadwiese's Avatar
ttt
Old Dec 2, 2008 | 10:55 AM
mikehawk's Avatar
you need a p28 ecu ..
Old Dec 2, 2008 | 04:49 PM
cadwiese's Avatar
so i would need a p28 ecu for a 95 b18 ls swap?
Old Dec 2, 2008 | 04:57 PM
94EG8's Avatar
Seagull Management
No, sure you'll get rid of that KS code, and gain two more while you're are it for the Vtec solenoid and pressure switch that aren't there and it'll run lean lean on top of that. A p75 shouldn't even look for a knock sensor anyway, which leads me to believe you may be misinterpreting the flashes when reading the code.
Old Dec 2, 2008 | 09:20 PM
INCNTRL4's Avatar
people are being wayyy to nice on here these days
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/engine-swap-info-faqs-how-ck-engine-lights-878010/
Old Dec 2, 2008 | 10:14 PM
cadwiese's Avatar
i didnt read the code the ref read the code and told me what it was. he said to get it cleared and come back.
ty for the info INCNTRL4
Old Dec 6, 2008 | 12:57 PM
cadwiese's Avatar
ttt
Old Dec 6, 2008 | 02:00 PM
94EG8's Avatar
Seagull Management
What are you bumping this thread for? Your engine does not have a knock sensor (Its not supposed to) A P75 ECU will not look for a knock sensor, therefore the ECU can't be throwing code 23. Go back and check the codes yourself and see what comes up.
93sidelsolvtec
Jan 22, 2007 03:50 PM
Trygge
May 14, 2004 09:16 PM
Defi4nce
Apr 25, 2004 10:01 AM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
jdmciviceg
Jun 9, 2002 07:56 PM
