knock code, replaced but still throwing the code
Old Jan 19, 2007 | 09:05 PM
93sidelsolvtec's Avatar
Default knock code, replaced but still throwing the code
93 civic ex
JDM b16a swap
p-30 ecu - virgin-
Knock code is being thrown. We replaced the sensor and its still there. only 92oct gas and timing is 100% perfect. Done by certified mechanic.
Wired correctly. 100% for sure on this
What other reasons a knock code will happen?
Old Jan 20, 2007 | 10:14 AM
SlowReaction's Avatar
Default Re: knock code, replaced but still throwing the code (93sidelsolvtec)
How is the wiring done? is it pinned from the shock tower to the ecu pin out or form the actual sensor? I'd check the pin and make sure its on D3. Nothing else would set the light off if you have a new sensor.
Old Jan 22, 2007 | 03:50 PM
Default Re: knock code, replaced but still throwing the code (SlowReaction)
ITS straight from the sensor to the ecu
EF_FEVER
Feb 22, 2007 12:32 PM
Jonzo
Jun 25, 2005 11:28 AM
roadawg
Feb 11, 2004 01:10 PM
jdmciviceg
Jun 9, 2002 07:56 PM
Chris_
Apr 15, 2002 07:01 AM
