Will DSM injectors fit in 99 si ? ? ? ?
Old Nov 28, 2008 | 08:44 AM
Joeski99Si's Avatar
Default Will DSM injectors fit in 99 si ? ? ? ?
i'v heard they do but i want more input, Will DSM blue top injectors work in a 99 si B16A2 without modification? ? ?
do i need clips or anything needed for them to work ?
Old Nov 28, 2008 | 08:57 AM
Schister66's Avatar
Man U FTW
IIRC, the only thing that may need a bit of modification are the 0-rings that hold the injector into the manifold. My question is, why are you doing this in the first place? Is there a turbo setup in the making?
Old Nov 28, 2008 | 11:38 AM
Joeski99Si's Avatar
no im just gonna throw them in for no ****ing reason ~!!!
YES THERE IS BOOST INVOLVED !
Old Nov 28, 2008 | 11:57 AM
93egboosted's Avatar
you need obd1 injector clips
Old Nov 28, 2008 | 01:45 PM
mookie86's Avatar
you will also need a resistor box or inline resistors(10watt 10ohm)
Old Dec 2, 2008 | 05:51 AM
Joeski99Si's Avatar
thanks
Old Dec 2, 2008 | 01:33 PM
dsm injectors are low impedance?
Old Dec 2, 2008 | 01:59 PM
Schister66's Avatar
Man U FTW
I hope that was meant in a joking way...If not, dont think i'll hesitate one second to lock this thread. You're a new member...tread softly
There is obviously a reason for my asking. There have been several threads about users wanting to run larger injectors for basically no reason. Now the next thing to consider is whether or not those injectors are large enough for your power goals...
Old Dec 2, 2008 | 02:14 PM
jfruauff's Avatar
yes dsm are low impedance. youll need obd 1 clips and a resistor back from a old school honda.
and i agree with schister i know many noobs hat asked me if a fuel pressure regulator would help on a stock car. dude i know i aint a honda-tech vet or anything but search will get you about 245 million results on this subject
Old Dec 2, 2008 | 02:15 PM
jfruauff's Avatar
o and joeski if a guy will a blue name askes you a question a answer that can be took as a smart *** remark might not be a good idea,lol
ceemarun
Aug 7, 2015 05:21 PM
ironiceghatch
Feb 11, 2008 01:26 PM
GReddy SI
May 24, 2004 10:12 PM
Smooth-GSR
Mar 26, 2004 10:16 PM
