Please help, no power after timing belt - b20T
Old Nov 28, 2008 | 06:35 AM
Boosted_B_Series's Avatar
Default Please help, no power after timing belt - b20T
Please help,
We put a timing belt on a car at our shop
Now the car has no power, revs really slow, builds boost real soon and cuts out and misses.
My first guess was that its a tooth off but the cam gears are dead on along with the crank mark is aligned within a 1/8" of the 1st mark [not the 3 marks]
I was not there when they took everything apart.
I'm kinda leaning towards the cams might be 180 off each. They said they did not move anything however.
Tonight I am going to put #1 or #4 on TDC and see if the valves are open or shut.
Please help, and I thank you for any ideas or suggestions.
dk
Old Nov 28, 2008 | 08:43 AM
boostedcivicsir's Avatar
Mr. Badwrench
well if it ran fine before the tbelt swap, you need to start there.
Old Nov 28, 2008 | 09:06 AM
MadScientistMatt's Avatar
I wonder if the balancer is damaged? I've heard of cases on other engines where the outer ring got separated from the rubber, causing the marks to slip and move to some other point than TDC.
Old Nov 28, 2008 | 09:13 AM
I know it has to be timing belt related.
I've installed several several timing belts.
The marks line up perfectly
Either its a tooth off on the crank pully [but I'm afraid a tooth either way wont even be close to the marks] or the cams are 180 off.
I was just looking for info on what exactly to check of how to tell whats what.
Thanks for your time,
dk
I have to figure this out, I built this car for my brother.
Old Nov 28, 2008 | 09:48 AM
Mr. Badwrench
pull it down, there is a mark on the oil pump, one on the crank sprocket.
both cam gears should be pointing "up". mark on the exh cam should be at 3 oclock, intake cam 9 oclock. remember the cams spin 1/2 the speed of the crank, so once every 4 strokes, the cams are 180* out. make sure you didnt line the crank sprocket up on the dowel pin instead of the timing mark.
Old Nov 28, 2008 | 10:15 AM
HiProfile's Avatar
I'd check base ignition. There's a chance the distributor is a little off now, that's about the only other thing I can think of.
Old Nov 28, 2008 | 12:36 PM
Thanks guys, I will check them in about an hr when I get to the shop.
I'm curious, if # 1 is at TDC all the valves should be shut right? That would be a good way to tell if the cams are 180 off right?
Thanks
Old Nov 28, 2008 | 02:02 PM
I'm not sure I understand were these marks are on the cams?
Old Nov 28, 2008 | 05:19 PM
slambedcivic's Avatar
Check the cogged pulley on the crank itself. Sometimes people goof up and put them on backwards causing the engine to be off 1 or 2 teeth. I forget which way it goes.
Old Nov 28, 2008 | 05:26 PM
Use this for reference
Old Nov 28, 2008 | 05:27 PM
He is refering to the TDC marks on the cam gears listed in the top left portion of the pic I posted.
kokopelli
Dec 17, 2011 07:39 AM
crxabi
Feb 28, 2010 11:28 AM
dadrought6
Feb 18, 2009 05:22 AM
macdaddydelux
Jul 9, 2007 08:55 AM
Thrillhouse
Aug 9, 2004 02:47 PM
