boost problems...
Old Nov 23, 2008 | 10:46 AM
l3adunkadunk's Avatar
Default boost problems...
hey i just bought an EG hatch, took some friends along to check it out and everything seemed really good, car is still great, just had a question, b16 engine swap from a 95 del sol with a t3t4 turbo. ss auto crome exaust manifold (dont make jokes, its what i have now, it will be changed when funds come) that has about a 2 inch crack accross the front welds. right now it runs just fine, but the turbo doesnt spool up till nearly 7000rpm. it gets up to 7 psi on the boost gauge (not sure but we think its working properly..) but not until 6 or 7000, any idea why?
if my boost gauge is off, how can i tell?
should the crack really make that much of a difference? (its not gaping open, very thin crack but you can feel exaust leak if you put your hand up near it...)
Old Nov 23, 2008 | 10:53 AM
2wheelhunter's Avatar
the crack may cause that i would say.. weld a bead across it and see how that works.. oh and yeah dont cheap out on a mani because you'll get what you pay for..
Old Nov 23, 2008 | 11:03 AM
b16_sol_707's Avatar
It is not creating boost because all the exhaust air is not getting to the turbo. I'd say your problem is the cracked manifold. A friend of mine had a similar problem with not building boost and it was because of a small leak where the turbo bolts to the manifold (1 bolt was loose).
Old Nov 23, 2008 | 12:09 PM
ok well im going to take it in as soon as possible to get it welded and well see how it works. any idea how much it would be? i think it would need to be tig welded.
Old Nov 23, 2008 | 12:20 PM
That manifold isn't really worth having it welded. You're better off buying a replacement.
Old Nov 23, 2008 | 02:53 PM
i know that, im not trying to keep it, just make it work until i can get a new one. i just need it to run clean while i work to save up for parts. im hoping i can get it welded for pretty cheap
Old Nov 23, 2008 | 03:12 PM
tx_ej8_49's Avatar
The turbo is not a ching-chang ebay turbo is it? That could be an issue too.
Old Nov 24, 2008 | 09:59 PM
its all an ss auto chrome kit as far as i know. turbo could definitly better but once again its kind of a project car and thats how it came. it will eventually be replaced. i have a buddy in salt lake who will be printing me a base map chip for the ecu this weekend and ill get the mani welded hopefully soon to and well see how it pulls then.
crvtkllr
Apr 14, 2007 06:55 PM
nicktagz
Aug 28, 2006 07:56 PM
2point3h22lude
Sep 10, 2005 08:48 PM
nzrnk
Apr 5, 2005 04:40 AM
genop
Mar 31, 2003 06:04 PM
