clutch issues
today my clutch went soft on me and it is almost impossible to get into gear. the temperature dropped below 30 this morning which unusally cold for this area. my question is could it just be a temp. issue or do i need to check my fluid levels. if so then where is the resevior located for the clutch? thanks in advance.
where exactlly is the reservior at? i am at work and only have acess to a few websites, this being one of them. please help me so i can put some fluid in before i have to drive home tonight.
If you have an actual Integra it should be just a few inches away from the brake reservoir around the vicinity of the brake booster on the driver's side firewall.
But if you're losing fluid in the cold then you have a 99% chance that your clutch master cylinder or slave cylinder is leaking. Or, there's a 1% chance that you just have bubbles in your clutch line, which can be bled from the slave cylinder on your transmission.
However if you have an OBD0 I believe the clutch is cable driven, so the year & model of your car would help also.
thanks for all the responses i got home because of yall. thanks alot. the clutch still feels a bit soft but i will look at it more indepth on monday. also the fluid that was in the reservior was almost black. should i change it or is this normal?
Jaydeep
Dec 1, 2011 05:35 AM
sniperslayer
17
Nov 5, 2005 06:29 PM
