Surge problem
Old Nov 20, 2008 | 01:14 PM
EvilleEG's Avatar
Default Surge problem
My car is surging. I cant find any vaccuum leaks and to bubbles in the coolant lines. It goes from 1k to 1800 and back down. Its very annoying and we can figure it out. Any ideas?. motor is a d16z6.
Old Nov 20, 2008 | 10:43 PM
slimjimming6688's Avatar
vacume leak at the brake booster maby or the iacv
Old Nov 21, 2008 | 05:39 AM
wrenchez81's Avatar
...or advanced ignition timing,,, idle air bypass screw adjustment,,,, throttle stop screw,,, or maybe even throttle cable adjustment....
Old Nov 21, 2008 | 06:17 AM
lilshady6796's Avatar
ok i had the same motor and same problem so check all your vacuum lines and coolent lines (mine was a coolent line from the intake manny to the head
Old Nov 21, 2008 | 06:24 AM
white4doorsi's Avatar
make sure your throttle cable is not too tight, your tps is set to the right voltage, and your idle air control is not broken
Old Nov 21, 2008 | 06:37 AM
here is what i had to replace
Old Dec 5, 2008 | 07:26 AM
EvilleEG's Avatar
I have a brand new IACV i just put on a week ago.Throttle cable is fine. Ill try the bypass screw. First thing i did was check vaccum leaks and coolant lines.
busha61067
Feb 13, 2010 09:00 AM
crxnonvtec
22
Sep 3, 2009 02:52 PM
jwizzie2001
Oct 24, 2008 05:46 PM
douboi
13
Oct 15, 2004 09:16 PM
WuRKD b16
Sep 24, 2003 11:44 AM
