idling problem
Old Feb 10, 2010 | 05:32 PM
busha61067's Avatar
Default idling problem
i have a 94 accord ex and when i start it up and its cold it it idles up and down until it warms up is this normal thanks
Old Feb 11, 2010 | 06:45 AM
PTVDesign's Avatar
Default Re: idling problem
check the antifreez and check FITV
Old Feb 11, 2010 | 06:49 AM
billyaccord96's Avatar
i adjusted my throttle cable so it always idle around 900 to 1000 rpm havent had any trouble since
Old Feb 11, 2010 | 04:30 PM
fleetw00d's Avatar
If you used the throttle cable to hold the throttle open slightly at idle, you're only masking the problem. With throttle closed, there is supposed to be about 0.3 to 0.4 inches play in the cable between the pulley on the throttle shaft and the bracket that holds the cable sheath. Your problem is likely in the Idle Air Control valve.
Old Feb 11, 2010 | 04:36 PM
mwaedow's Avatar
I agree with the above statement. It's either the IACV or a vacuum leak, causing the erratic idle. The IACV receives a signal from the coolant temp sensor that gradually grounds it out to reduce the voltage to it, causing it to close gradually as the engine warms up. If you have erratic idle at cold startup, then something is funky with that system.
Old Feb 11, 2010 | 05:32 PM
B18B1-Crx's Avatar
yes, check anit-freez level and check your vaccums and douple check the IACV...
Old Feb 12, 2010 | 07:59 AM
nus_dogg's Avatar
Its not your IACV, its the FITV. FITV is there to control your idle at cold then when it warms up, then the IACV comes into play. Remove it from underneath the TB, and adjust the white wax ball down.
Old Feb 12, 2010 | 01:52 PM
cstone's Avatar
+1
thats exactly what i was thinking as i was reading this thread.
Old Feb 12, 2010 | 02:26 PM
Dannyvho's Avatar
Originally Posted by cstone
+1
Another vote for the FITV here: OP clearly stated that the problem only occurs at startup when the engine is still cold, that is exactly when the FITV is supposed to do its work.
Old Feb 12, 2010 | 05:27 PM
fleetw00d's Avatar
UNCLE! FITV! I haven't had trouble with either FITV or IACV on any of mine - I'll keep it mind if I do. Still shouldn't adjust the throttle cable to keep idle up.
Old Feb 12, 2010 | 11:15 PM
cstone's Avatar
^also a very true statement^ you should also not use the idle adjustment screw to try to fix it as i have heard of others doing.
Old Feb 13, 2010 | 07:30 AM
DrZFiNeSt's Avatar
Agree with what everyone else posted,also a clogged EGR can have something to do with this as well.
Old Feb 13, 2010 | 09:00 AM
cstone's Avatar
i believe a clogged EGR will generally make it either constant or more sporadic depending on how badly clogged it is. but yes it deffinitely could have something to do with it.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
Hackura
Mar 12, 2009 03:17 PM
jwizzie2001
Oct 24, 2008 05:46 PM
EJuno
Jan 29, 2008 06:23 PM
emooheo
Mar 23, 2007 02:34 PM
