rpm's is going crazy!
Old Nov 9, 2008 | 12:57 PM
egthomas's Avatar
Default rpm's is going crazy!
My rpms is going up and down. It goes from 1000 to 1600rpm and it keeps going and going. Up and down and up and down. Kinda like its breathing. What's my problem?
Old Nov 9, 2008 | 12:58 PM
jimmy o.'s Avatar
IACV
Old Nov 9, 2008 | 01:14 PM
slo_hatch's Avatar
Default Re: (jimmy o.)
Originally Posted by jimmy o.
IACV
possible MAP sensor
Old Nov 9, 2008 | 01:58 PM
egthomas's Avatar
Default Re: (slo_hatch)
map sensor?
were is this located?
and whats the iacv?
ive heard these words before but never really looked into them.
Old Nov 9, 2008 | 02:21 PM
Icon_Ed6's Avatar
Default Re: rpm's is going crazy! (egthomas)
Check ur IAC, not always it... but usually. Its behind the intake manifold, it looks like a cylinder with 2 12mm bolts in it.
Old Nov 9, 2008 | 02:22 PM
slo_hatch's Avatar
Default Re: (egthomas)
your map sensor is right on top of the TB...just replace it. clean the iacv and see if that fixes it first.
Old Nov 9, 2008 | 02:25 PM
Honda-Pilot's Avatar
Start by checking for a vacuum leak.
IACV = Idle Air Control Valve.
Old Nov 9, 2008 | 04:00 PM
lilshady6796's Avatar
Default Re: (Honda-Pilot)
thats exaclty what mine was dointill i got the temperature hose, it goes from the head to the intake manifold not sure what is called but it might be mssed up wweird but will cause rpms to do this
Old Nov 9, 2008 | 05:07 PM
egthomas's Avatar
Default Re: (lilshady6796)
a little hose that went from the intake manifold to the brake cylinder thing, had a crack so i cut it, put it back, and now its all goood.. haha.
oh and by the way,
that "stop leak" for radiators works really good.
Old Nov 9, 2008 | 05:20 PM
egthomas's Avatar
were the arrows point is were the crack was. but i cut it and fixed it.
Old Nov 9, 2008 | 07:19 PM
That's a vacuum line going from the intake manifold to the brake booster. If it had a crack in it, it would definitely cause your problem.
Old Nov 10, 2008 | 06:27 AM
ShawnbobHatch's Avatar
distributer possibly?
Old Nov 10, 2008 | 07:21 AM
slo_hatch's Avatar
Default Re: rpm's is going crazy! (ShawnbobHatch)
no if it was the dizzy it would quit running completely...unless you mean like the rotor button and cap. i have never heard of a dizzy causin this problem. i would check vacuums too...i forgot about tellin you to check those.
FERIOkid
Nov 11, 2006 04:07 PM
88 rex
Aug 16, 2005 06:49 PM
Ldc4S
Jan 25, 2004 08:33 AM
89JDMcrx
Aug 7, 2003 08:31 PM
SUMORex
Mar 24, 2002 05:19 PM
