what the difference between h22 long block and short block
Old Nov 6, 2008 | 06:04 PM
x22xhyper's Avatar
Default what the difference between h22 long block and short block
just curious...
Old Nov 6, 2008 | 06:14 PM
ShoofIsLudin's Avatar
the long block is a full engine with accessories (power steering pump, AC compressor, Alternator, distributor, intake manifold, etc.)
a short block i'm pretty sure is just the bottom end (block, crank, pistons, rods, oil pan, oil pump, etc..... with NO head)
Old Nov 6, 2008 | 08:06 PM
bbsprelude's Avatar
Default Re: (ShoofIsLudin)
you would be correct
Old Dec 2, 2008 | 10:18 AM
BuddyC's Avatar
do blocks differ between one that came from an automatic and one from a manual?
Old Dec 2, 2008 | 08:11 PM
TheJGB3's Avatar
No, a long block does NOT include accessories (power steering pump, AC compressor, Alternator, distributor, intake manifold, etc.) It's just a cyl head on a shortblock.
A short block is a block with crank and pistons only.
If you are purchasing a "JDM complete motor swap", it WILL include the accessories since the seller usually includes these as well and trans, half shafts, and ECU.
Old Dec 4, 2008 | 07:14 PM
ace260's Avatar
I'm curious about this as well.
Old Dec 4, 2008 | 07:21 PM
BLUBB2's Avatar
It shouldnt be no difference at all
EK9Rider
11
Sep 23, 2006 06:40 AM
JapJunkie
Mar 16, 2004 09:58 PM
XViEtBoiX
13
Jun 27, 2003 11:08 PM
slowestcivicever
Apr 16, 2003 09:46 AM
KOME
Dec 6, 2002 03:02 PM
