help with vtec wont engage
Old Nov 5, 2008 | 05:10 PM
thermostate82's Avatar
Default help with vtec wont engage
So I bought one of those ob2 scaners from wal-mart and tryed to erase the p0117 code it keeps spiting out. I just replace the coolent temp sensor and I am at my wits end over this. I checked all the groundings / connections
Old Nov 5, 2008 | 08:50 PM
Chris F's Avatar
Default Re: help with vtec wont engage (thermostate82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermostate82 &raquo;</TD></TR><TR><TD CLASS="quote">So I bought one of those ob2 scaners from wal-mart and tryed to erase the p0117 code it keeps spiting out. I just replace the coolent temp sensor and I am at my wits end over this. I checked all the groundings / connections</TD></TR></TABLE>
Check the resistance of the wire to ground, see if it's shorted. P0117 should be a short. Could be a bad ECU but hopefully not. Do you know someone with the same car/ECU that you could borrow for a little while?
Old Nov 5, 2008 | 08:59 PM
Acidcrakker's Avatar
Default Re: help with vtec wont engage (Chris F)
Wait, have you bothered to reset the ECU the proper way, with the battery?
Unkless the code scanner can manuelly erase them with out resetting the battery
Old Nov 6, 2008 | 06:43 AM
SKDRCR's Avatar
Default Re: help with vtec wont engage (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Wait, have you bothered to reset the ECU the proper way, with the battery?
Unkless the code scanner can manuelly erase them with out resetting the battery</TD></TR></TABLE>
You can also pull the 10 amp radio fuse for 15 seconds and it will reset it.
Old Nov 6, 2008 | 09:19 AM
Default Re: help with vtec wont engage (SKDRCR)
I did that already, I changed the ect sensor, then disconnected the battery for 10 min then went out and bought a OBD2 scanner and tried to erase the code all it did was blink and come back on.
Old Nov 6, 2008 | 10:29 AM
4WSi_guy's Avatar
92 CiviC H.B
Apr 20, 2010 02:36 PM
tx95excoupe
Apr 27, 2007 04:07 PM
Metal Head
Sep 28, 2006 11:39 PM
hondacrx90
10
Apr 9, 2004 05:45 AM
Bseriesy0
Nov 29, 2003 11:46 AM
