Barometric Sensor - Code 13 - Please Help!!
Old Apr 26, 2007 | 07:25 AM
tx95excoupe's Avatar
Default Barometric Sensor - Code 13 - Please Help!!
my check engine light came on again on the 95 ex and i ran the code on it and the code came up with code #13 Barometric Pressure Sensor. Does anyone know where this is and how to test it. Thanks for the help in advance.
Old Apr 26, 2007 | 09:46 AM
slomofo's Avatar
GDD Member
Default Re: Barometric Sensor - Code 13 - Please Help!! (tx95excoupe)
Click on the pic:
Old Apr 26, 2007 | 10:35 AM
Default Re: Barometric Sensor - Code 13 - Please Help!! (slomofo)
thanks man..how do you do the ecu reset procedure.
Old Apr 26, 2007 | 11:20 AM
slomofo's Avatar
GDD Member
You can use a scan tool or else disconnect the battery and ECU fuse for ECU Reset.
Old Apr 26, 2007 | 01:11 PM
Default Re: (slomofo)
and the ecu fuse is in the fuse box under the hood right.
Old Apr 26, 2007 | 01:16 PM
Default Re: (tx95excoupe)
if you unplug the battery for 10 min..that by itself doesnt reset the ecu....is that correct.
Old Apr 26, 2007 | 03:55 PM
ok i unplugged the battery and the ecu fuse..and let it sit for 20 min. or so..and when i plug it all back in and try to run the code on it the cel is solid and doesnt blink at all...does that mean its fixed.....
Old Apr 26, 2007 | 04:06 PM
slomofo's Avatar
GDD Member
Problem is intermittent, drive it around and test again.
Old Apr 27, 2007 | 10:28 AM
i drove it around and this morning on my way in to work it came back on. the car runs fine..is there anyway i can take the CEL bulb out to get it inspected or something....and then put it back in after....or does the code 13 throw the ecu into "limp mode" and it wont pass inspection.
Old Apr 27, 2007 | 02:36 PM
slomofo's Avatar
GDD Member
Why don't you just clear the code right before you do your inspection?
Old Apr 27, 2007 | 04:07 PM
i dont want the cel to come on while they are inspecting it..then it will fail.
nickeynick
17
Feb 2, 2011 11:02 AM
Doug684
Mar 3, 2004 04:45 PM
GeorgeY
Jun 29, 2003 08:59 AM
1EK1EG
Jun 13, 2003 05:13 PM
ArchAngel Sabastian
Oct 23, 2001 07:39 PM
