HELP**D16y7 Swap into EG
Old Nov 4, 2008 | 10:55 AM
quiocho8o8's Avatar
Default HELP**D16y7 Swap into EG
i just did a d16y7 swap into an EG and it doesnt wanna start.
the motor came out from an other swap EG and we started the motor before we pulled it out
it had the same ECU and the motor was out from a 96 civic so its OBD1
im guessing the injectors will not open up because if i spray fuel in to the TB it starts for a while and yes its giving spark
Old Nov 4, 2008 | 11:02 AM
wrenchez81's Avatar
Default Re: HELP**D16y7 Swap into EG (quiocho8o8)
96 is obd2 amigo!!! what your lacking is fuel pulse....... what did you do about converting your obd1 dizzy to a 2?? what ecu are you using??
Old Nov 4, 2008 | 11:07 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Does the check engine light come on, then go out after you turn the key into the on position? Do you hear a faint clink type noise from under the dash when the check engine lught goes out, if it goes out?
Check the ground location at the thermostat housing. If it's loose/not bolted down it can cause no starts and no fuel pressure.
Old Nov 4, 2008 | 11:09 AM
wrenchez81's Avatar
Default Re: HELP**D16y7 Swap into EG (B18C5-EH2)
lol!! like a main relay!!!
Old Nov 4, 2008 | 11:12 AM
quiocho8o8's Avatar
i tought 97+ is OBD2 haha ohh wells
but we are using the same dizzy and ECU off the same car we got the motor off from
yes there is the clicking sound under the dash when the key is turned on
Old Nov 4, 2008 | 11:35 AM
wrenchez81's Avatar
lol!! my friend 96+ is obd2 ....... you sure you dont have an ek?? what year is your civic and hatch or 4 door???
Old Nov 4, 2008 | 11:42 AM
quiocho8o8's Avatar
Default Re: HELP**D16y7 Swap into EG (wrenchez81)
haha i dont really know about these old motors...its all K series for me
its a 92 hatch
the motor came out from a 92 coupe (its got swapped from a 96 civic)
Old Nov 4, 2008 | 11:50 AM
EGfosho's Avatar
OG Tech
do you hear your fuel pump kick in when you put the key into on position?
Old Nov 4, 2008 | 11:51 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quiocho8o8 &raquo;</TD></TR><TR><TD CLASS="quote">
its a 92 hatch
the motor came out from a 92 coupe (its got swapped from a 96 civic)</TD></TR></TABLE>
Not that its really relevant, but it didn't come out of a '92 coupe, they don't exist. For whatever reason honda didn't introduce the coupe until '93
Old Nov 4, 2008 | 12:00 PM
wrenchez81's Avatar
Default Re: HELP**D16y7 Swap into EG (94EG8)
^^^ x2 amen brotha or the del slow!!!
Old Nov 4, 2008 | 12:02 PM
wrenchez81's Avatar
so did u swap the engine harness, ecu and all?? or just engine??? see if you have the main relay from the other car.. u may wanna try that...
Old Nov 4, 2008 | 12:06 PM
quiocho8o8's Avatar
ohhh dam i gotta get my **** straight ahaha
yes we swapped the harness and ecu and yes i could hear the pump
im gonna try and change the relay
im gonna head over my frens house and try this out
thankx for the help so far guys
im gonna come back with results
Old Nov 4, 2008 | 04:01 PM
quiocho8o8's Avatar
problem fixed but there was nothing to do of the things you guys told me
Old Nov 4, 2008 | 04:05 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quiocho8o8 &raquo;</TD></TR><TR><TD CLASS="quote">problem fixed but there was nothing to do of the things you guys told me </TD></TR></TABLE>
Ok, so what was the problem?
Old Nov 4, 2008 | 04:06 PM
drave's Avatar
What was it then?
Old Nov 4, 2008 | 04:35 PM
wrenchez81's Avatar
Default Re: HELP**D16y7 Swap into EG (drave)
^^^^^^^ word ta big bird!!!!!! and when you see dog ,, leland, and chick tellem i said sup!!! jk!!
Old Nov 4, 2008 | 08:53 PM
EGfosho's Avatar
OG Tech
Old Feb 1, 2022 | 08:36 PM
20099558's Avatar
What was it?
Old Feb 2, 2022 | 12:43 PM
wunfstgsr's Avatar
Loved
Community Favorite
krazoeg6
Mar 17, 2012 11:26 AM
Jej2386
15
Feb 12, 2010 02:17 AM
vtec4max
Apr 25, 2007 07:49 PM
tequilakid
Jul 16, 2004 11:51 AM
datsun510dude
Feb 13, 2003 05:58 PM
