Need to Retard my timing
From: Somewhere in the United States, united states
I have a b18b1 and I need to retard my timing -4*. Stock timing is 16*. This is where I get confused. I believe I will have to retard it to 12*. Is this correct?
From the website CRS and looking at the diagram the crank pulley has one mark that is 0* then 3 marks grouped together 14*16* 18*.
How do I know where the 12* mark is?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian »</TD></TR><TR><TD CLASS="quote">Ummm, why do you have to retard it?
And 12 degrees BTDC is advancing the timing.</TD></TR></TABLE>
ok if 12* is advancing it then what would i need to set it at. I know i need to retard it 4* from stock timing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondateg10 »</TD></TR><TR><TD CLASS="quote">I know i need to retard it 4* from stock timing.</TD></TR></TABLE>
Why?
20 degrees BTDC would be 4 degrees retarded from stock.
Why?
Why?
20 degrees BTDC would be 4 degrees retarded from stock.</TD></TR></TABLE>
FI
ok so 20* is where i put it. now back to my OP how do I know where 20* is at
Why?
FI
back to what you said. I thought - is retard and + is advancing. so from 16* i would have to -4 which would make it 12*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondateg10 »</TD></TR><TR><TD CLASS="quote">back to what you said. I thought - is retard and + is advancing. so from 16* i would have to -4 which would make it 12*</TD></TR></TABLE>
Yeah, you're right. I had it backwards.
You'll need an advance timing light. I hope you don't expect great drivability or reliability with this "tuning" method.
VSM EXtasy
Jul 19, 2003 10:19 AM
