ignition timing?
Old Sep 23, 2003 | 09:10 PM
97vtec's Avatar
Default ignition timing?
The specs for stock timing on my car is 12* +/- 2degrees btdc. I ran a timing light and it read 10degrees, so I am still w/in parameters of stock timing. I want to retard the timing a degree or two, now the 12degrees stock timing is retarded from top dead center right? I just want to make sure I retard it and not advance it. EX: 14* would be 2degrees retarded, right?
Old Sep 23, 2003 | 10:25 PM
Padawan's Avatar
Darth ModerVader
Default Re: ignition timing? (97vtec)
If you are currently at 12 degrees BTDC, retarding 2 degrees would put you at 10, and advancing 2 degrees would put you at 14.
mortificationrock
Jul 10, 2007 04:26 PM
gsrguy
Feb 7, 2004 02:10 PM
