Anyone here running an AEM EMS yet?
Old Jul 30, 2002 | 07:56 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Anyone here running an AEM EMS yet?
Hey guys. I just installed my EMS, 450cc DSM injectors and a new FPR last weekend.
I'm using a map from a JRSC'd B16A with about the smae mods as me. The MAP worked great with just few tweaks to the fuel settings just to be safe. The car runs fine under boost and gets zero knock but it is a little rich. I was able to get it drivable just off of datalogging the stock sensors.
The problem I'm having is cold starting the motor and keeping a steady idle. I'm pretty sure that the idle problem is caused by me having the fuel pressure to high (46psi at idle) but I wanted to make sure I didn't blow it up because I didn't have a wideband. I'm going on the dyno in two weeks to tune it for power but in the meantime I want to work on the idle/start problem.
Is anyone here running one and having success with it? If so, can I look at your map to see what the differences are between your idle and start controls and mine? Help would be greatly appreciated.
Old Jul 30, 2002 | 08:08 AM
RTW DC2R's Avatar
Default Re: Anyone here running an AEM EMS yet? (newt2)
I should have mine in about 2 weeks. Im very anxious to get it going.
Old Jul 30, 2002 | 08:18 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Anyone here running an AEM EMS yet? (RTW DC2)
I'r excited about it. In fact this is the first time I've been excited about my car in a few months. I was starting to get frustrated with the constant tuning issues. I'd change a few things get it running good, and then a couple weeks later it would seem to be back where I started. Reset the ECU, retune it, runs good for a few weeks, ad infinitum....
Now I've got the car running and it's faster than it's ever been even running pig rich like it is. No more flat spot from 7000 on up anymore it just keeps pulling linearly.
It's a complex system but if you have a clue about what you're doing and are carefull, it's not as bad as I've heard it made out to be. There's pleny of work still left to do, but with only three hours invested so far (that's for everything too, injector rewire, fpr install....) and I have a driveable car, I think that's doing pretty good for a standalone.
Old Jul 30, 2002 | 08:22 AM
CPR's Avatar
CPR
I've been doing research and I vaguely remember you saying something along the lines of having datalogging issues. If I remember correctly, datalogging using a laptop had no issues but datalogging onto the ECU itself was causing problems. Was there ever a fix for this?
Old Jul 30, 2002 | 08:29 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Anyone here running an AEM EMS yet? (CPR)
I don't think it ws me that said that because this is the first time I've had the ECU in the car. I have heard the same thing, but the new software's release notes claims to have fixed it. It worked fine for me, you have to manually set up all the logging but that's just click File ---> Add ----> Pick your sensor. I haven't figured out the math channels yet, in fact I'm not even sure what you would use that for. I'm just planning on shooting for 12.2:1 AF ratio and as much timing as possible without knock. I don't think I'll need to run tricky equations on various sensor readings to do that.
Maybe if you're good with math you can have it estimate hp by using load and speed sensor readings or something like that with it...
Old Jul 30, 2002 | 08:33 AM
RTW DC2R's Avatar
Well I dont plan to touch it myself, Im letting a tuner shop do the work. Its costly, but Im way more comfortable letting a AEM certified tuner handle it on a dyno then me fussing with it in my drive way. And yes I have not heard a bad thing about the AEM unit yet so thats why Im so excited to get it up and running.
Old Jul 30, 2002 | 08:38 AM
Black R's Avatar
25 Year Member
local guy has it on his itr and drag 3 setup running 6psi, and we spend some time playing with it this past sunday...
it was pretty cool for sure...
I'd say play with the tps voltage settings too, as we had to do this to get a steady idle... We also had to lean out the stock b16 w/ boost maps for idle so it wouldn't kill the car (running too rich).
ILR or ILOVERACING has been playing with it a bunch... try sending him an IM...
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
I want to do it myself, I figure I'll have to be changing things quite a bit and I would be better off in the long run if I learned how to use it. Plus it's kind of fun if you're into that sort of thing.
I may go sensor crazy in the future too. I want to run a EGT probe right into the ECU and set it to add fuel if EGTs get too high. I want a wideband so I can tune on the street/strip, Porsche makes one for $300 that should work great for that. When the traction control update comes out, I'm looking to get that working too. From what I unserstand you may need some extra/different wheel speed sensors for that.
Old Jul 30, 2002 | 08:46 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Anyone here running an AEM EMS yet? (Black R)
Thanks I'll give that a shot.
Old Jul 30, 2002 | 08:48 AM
BDiddy's Avatar
I saw someones this weekend(no names as I dont know if he wants it knows)
It was pretty sweet to watch that graph... And you can slam it shut when it says danger to manifold!!! LOL!!!!
Old Jul 30, 2002 | 08:49 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Anyone here running an AEM EMS yet? (Megatron)
And it can control TWO bottles of NAWWWS!
Old Jul 30, 2002 | 08:50 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Hey Megatron, if you wouldn't mind maybe you could point him to this thread?
Old Jul 30, 2002 | 09:04 AM
D's Avatar
D
Where's everyone buying these units from? paying retail???? call me, curious...
D
Old Jul 30, 2002 | 09:12 AM
SpoonCivic's Avatar
New User
try http://www.aempower.com
there is a BBS for EMS users. A lot of help from AEM engineers and ppl with experience. I've been on the board for the past couple days, just to educate myself upon arrival of my AEM unit.
Old Jul 30, 2002 | 09:13 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Anyone here running an AEM EMS yet? (D)
I paid $1300 for mine from JDMClub.com (MarkAccord on this board).
They're not cheap but they are sweet.
Old Jul 30, 2002 | 09:34 AM
EVIL CETANE's Avatar
Magatron is talking about me. And mine is for sale If anyone wants it
Old Jul 30, 2002 | 09:35 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Anyone here running an AEM EMS yet? (cetane)
How's your idle? Can I get you to email me a copy of your map?
Old Jul 30, 2002 | 09:38 AM
CPR's Avatar
CPR
Any reason why you're selling it?
Old Jul 30, 2002 | 09:44 AM
RTW DC2R's Avatar
yes, why are you selling??
Old Jul 30, 2002 | 10:16 AM
My car is being parted out, as we type, I have a list a mile long of parts.
The car is also for sale
Old Jul 30, 2002 | 12:59 PM
ttt
Old Jul 30, 2002 | 07:02 PM
RATEDR's Avatar
Try lowering your TPS voltage. On my base map it was at 4.40...for my car to idle it needs to be at 0.04. A HUGE difference. Also make sure Early Sinc is turned ON.
Old Jul 30, 2002 | 07:46 PM
xjohnx's Avatar
anybody know anyone on the east coast that could tune one of these things properly?
Old Jul 31, 2002 | 04:01 AM
RATEDR's Avatar
Default Re: Anyone here running an AEM EMS yet? (xjohnx)
Turbo Tune in Greensboro, NC
Epik Motorsports in Myrtle Beach, SC
R&D Motorsports in NC?
TJ and Len in Atlanta (in about 6 months or so )
petroi77
Engine Management and Tuning
Aug 26, 2013 12:27 AM
jdm.ej
Nov 16, 2005 05:08 PM
Hondadrvr215
Mar 31, 2004 10:47 AM
Tegman88
Jul 11, 2003 06:35 AM
ITR41
May 14, 2003 08:23 PM
