I've never seen a vtec solenoid like this??
Old Oct 22, 2008 | 11:18 AM
iamthefollower's Avatar
Default I've never seen a vtec solenoid like this??
I had bought my B16a, and for some reason the vtec solenoid didn't have a pressure switch in it, I got to looking and there isn't even any threads in the solenoid for one, I've known this for awhile and the car is still under construction at the moment, just hadn't gotten around to posting anything on it. Does anybody know the reasoning for this??
Old Oct 22, 2008 | 11:23 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: I've never seen a vtec solenoid like this?? (iamthefollower)
IIRC OBD2 JDM B motors don't have the VTEC pressue switch.
Old Oct 22, 2008 | 11:24 AM
Default Re: I've never seen a vtec solenoid like this?? (mcvtec)
what's IIRC??? lol.. sorry just havnt' seen that one.
Old Oct 22, 2008 | 11:27 AM
BryanM.'s Avatar
Resident Gearhead
If I Remember Correctly
Old Oct 22, 2008 | 11:40 AM
raidacaipo's Avatar
looks like someone might have taken off the vtec oil pressure switch? well my jdm solenoid doesnt even have a hole in it for the vtec oil pressure... interesting..
Old Oct 22, 2008 | 11:42 AM
Oh lol gotcha lol.. Well I was just wondering on why, because I knew the USDM obd2's came with the oil pressure switch, but you're right this is a JDM Obd2 going in my car.. So I just need to get a new vtec solenoid casing and i'll use the top of this one, it might do pretty. I got this motor from Best Japanese Engines and they had taken it in on trade, the guy wanted this motor out and put a c5 in his car, I think he was mad because vtec didn't work lol... thanks man.
Old Oct 22, 2008 | 11:46 AM
Default Re: I've never seen a vtec solenoid like this?? (raidacaipo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raidacaipo &raquo;</TD></TR><TR><TD CLASS="quote">looks like someone might have taken off the vtec oil pressure switch? </TD></TR></TABLE>
yea that's what I was thinking, but i can't even screw the oil pressure switch into it ... I'll just get a new one I guess lol...
Old Oct 22, 2008 | 11:48 AM
raidacaipo's Avatar
oh then its jdm.. you wouldnt need it if you have a jdm ecu as well.. unless you have a usdm ecu then you would need one or you can do the bypass trick for the oil pressure switch
Old Oct 22, 2008 | 11:53 AM
Nope I have a Chipped p72 that i'm hooking it up to.. what do you mean the bypass trick??? I hope you're not talking about hooking it up on switch lol... i've done that a few times I just want this one done right lol.
Old Oct 22, 2008 | 12:13 PM
B16aCRXSi's Avatar
you can get a chip burned with vtec pressure switch disabled, and have one wire vtec, just like stock
Old Oct 22, 2008 | 12:20 PM
94EG8's Avatar
Seagull Management
Info below is all taken from Katman's ff-squad website, a truly excellent resource.
Take the power wire for the VTPS and splice it into the VTS wire, then take the VTPS ground wire and ground it to the actual body of the VTEC Solenoid - that's it! If done correctly, your ecu will not throw a check engine light for code 22 (VTPS). If you wind up using a JDM OBD2 ecu, you do not need to perform this VTPS fix, because the JDM OBD2 ecu doesn't look for a VTPS.
Old Oct 22, 2008 | 12:33 PM
raidacaipo's Avatar
http://www.phearable.net/tech/...s.gif
Old Oct 22, 2008 | 01:45 PM
Awesome thanks a lot guys.
Tunerguy1989
May 5, 2009 02:54 PM
raidacaipo
May 10, 2008 09:36 PM
blueeg
Apr 25, 2006 11:16 AM
gunnis
Jan 17, 2006 03:36 AM
iphatcrxi
Nov 30, 2004 09:14 AM
