Turbo b16a?
Old Oct 22, 2008 | 12:05 AM
924doorEG's Avatar
Default Turbo b16a?
Hey guys im just about to swap out my single slam for a b16, my first b series motor, and i was wondering how good to jdm b16a's handle under boost? im only thinking about running 8lbs on mine? safe? i would like some response on it and maybe what i should do to it wisely? this is going to be my daily driver....im looking for maybe 13's 12's might be pushing it on a dd....thanks guys.
Old Oct 22, 2008 | 06:48 AM
Schister66's Avatar
Man U FTW
First of all, dont make your power goals in terms of boost....rather, make them in terms of whp. Which for a stock B16 (and most other B series) is around 300whp on the stock block.
Old Oct 22, 2008 | 08:09 AM
neoc03's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">First of all, dont make your power goals in terms of boost....rather, make them in terms of whp. Which for a stock B16 (and most other B series) is around 300whp on the stock block. </TD></TR></TABLE>
X2
Every turbo is going to make a different amount of power at each PSI. I wouldn't push it much beyond 300whp for a DD.
Also you need to make sure your motor is healthy enough for boost.
You need to set a goal for your whp then pick your parts accordingly.
Old Oct 22, 2008 | 08:50 AM
23hatchturbo's Avatar
Default Re: (neoc03)
what they said you should have no problem building a 12sec daily just do your home work ask questions and the most important part is find a tuner u can trust.
And dont go cheap on tunning pay the extra money for the dyno tune so you no exaclty what your cars doing.
Old Oct 22, 2008 | 10:35 AM
924doorEG's Avatar
alright guys well thanks for the replys....i did some homwork, and im thinking i want about 250whp no more for my b16, and when i get it i will do compression and leak down test before anything major
Old Oct 22, 2008 | 11:46 AM
B.'s Avatar
B.
400 HP Club
Default Re: (924doorEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 924doorEG &raquo;</TD></TR><TR><TD CLASS="quote">alright guys well thanks for the replys....i did some homwork, and im thinking i want about 250whp no more for my b16, and when i get it i will do compression and leak down test before anything major</TD></TR></TABLE> buahaha you say that now, but just wait...
Old Oct 22, 2008 | 11:58 AM
neoc03's Avatar
You will get tired of 250whp very quickly. I give it 6 months before your buying pistons and rods lol.
Old Oct 22, 2008 | 12:14 PM
GEN2 LS's Avatar
Loved
yeah 250whp lasted me for like 2 weeks and then my car felt slow again. In the process of putting a bigger turbo on, and turning up the boost and shooting for 400+hp
Old Oct 22, 2008 | 11:11 PM
924doorEG's Avatar
your right im talking out of my azz right now lol....but FOR NOW key words for now lol i want about 250 275 tops.....now is that gonna be easy to do? i mean the b16 im about to order......then the turbo kit any suggestions on what i should do to keep it running clean and strong? i got a good tuner so thats no prob and im going to tune on hondata or crome
Old Oct 22, 2008 | 11:55 PM
418whpturboD's Avatar
my dd is a turbo b16 and i went 12.2 and is stock except for head studs and headgasket..
Old Oct 23, 2008 | 04:28 PM
ekhonda87's Avatar
Default Re: (418whpturboD)
as long as you buy quality parts, you will be able to make a dependable 300whp.
Old Oct 23, 2008 | 08:40 PM
924doorEG's Avatar
well im buying the turbo kit from ebay, but im upgradeing the turbo and header....is that going to be decent?
Old Oct 24, 2008 | 08:33 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 924doorEG &raquo;</TD></TR><TR><TD CLASS="quote">well im buying the turbo kit from ebay, but im upgradeing the turbo and header....is that going to be decent?</TD></TR></TABLE>
NO.
If you're going to buy parts, get quality ones the first time. You can piece a turbo setup together very easily. If you want to use Ebay IC piping, an Ebay IC and an Ebay bov, that's fine. The other parts are total garbage though. I would search through the marketplace and see what's out there.
Just know that if you skimp on buying good parts, you're more than likely going to have problems.
b20vtech
Feb 14, 2015 01:49 PM
fredo818
May 14, 2011 10:03 PM
alexm
Dec 21, 2007 08:05 PM
hondamn1320
Dec 2, 2007 05:45 AM
grizzy225
14
Mar 15, 2007 08:53 PM
