tial bov open at idle. ne1 try spacers under spring?
Old Oct 19, 2008 | 02:07 PM
got wide's Avatar
Default tial bov open at idle. ne1 try spacers under spring?
i had a problem with my tial q surging so i checked the engine vac at idle and had around 6-8 in. of vac with skunk 2 pro1's and pnp head. so i got the lightest spring tial had but now with the car parked the valve will stay 3/4 open at idle and will fully open with any throttle. now i cant see under the hood while driving but i cant really hear much of a "blow off" so im not sure its fully closed under load either. has anyone tried to put washers under the springs to raise the spring rate/pressure?
also how loud should this bov be? ive yet to hear it opperate correctly and am curious to know how noticable it will be over the sound of the full 3in unmuffled exhaust?
Old Oct 19, 2008 | 03:32 PM
sgnlab's Avatar
Default Re: tial bov open at idle. ne1 try spacers under spring? (got wide)
it is in vacuum so it will be open @ idle... When in boost it will close..
Old Oct 19, 2008 | 05:44 PM
CoreyR's Avatar
Default Re: tial bov open at idle. ne1 try spacers under spring? (sgnlab)
yup should be open at idle. i could never hear mine with a 3" open downpipe.
Old Oct 20, 2008 | 06:49 AM
Muckman's Avatar
Moderator in Chief
Its supposed to be open some but not fully at idle. You can try a stiffer spring.
We were getting surge on a SRT-4 so we went with a softer tial spring. But it was open full at idle so we shimmed it with 1 large washer. just drilled out the center.
Old Oct 20, 2008 | 08:10 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: tial bov open at idle. ne1 try spacers under spring? (Muckman)
go to tials site, there is a chart, pick your spring according to your engine vacuum.
Old Oct 20, 2008 | 09:16 AM
TiAL's Avatar
if you have 6-8in/hg vac there is no way the -6psi spring is open at idle...it cracks at -12in/hg.
where do you have your boost/vac referenced?
90210tegrunner
May 20, 2013 08:33 PM
JDMCRX
Jun 7, 2007 12:31 PM
o'malley_808
Aug 24, 2006 10:08 PM
igo4bmx
Apr 12, 2005 04:45 AM
TurboTegB18c
Sep 12, 2004 10:58 AM
