tial bov open at idle. ne1 try spacers under spring?
i had a problem with my tial q surging so i checked the engine vac at idle and had around 6-8 in. of vac with skunk 2 pro1's and pnp head. so i got the lightest spring tial had but now with the car parked the valve will stay 3/4 open at idle and will fully open with any throttle. now i cant see under the hood while driving but i cant really hear much of a "blow off" so im not sure its fully closed under load either. has anyone tried to put washers under the springs to raise the spring rate/pressure?
also how loud should this bov be? ive yet to hear it opperate correctly and am curious to know how noticable it will be over the sound of the full 3in unmuffled exhaust?
Moderator in Chief
Re: tial bov open at idle. ne1 try spacers under spring? (got wide)
Its supposed to be open some but not fully at idle. You can try a stiffer spring.
We were getting surge on a SRT-4 so we went with a softer tial spring. But it was open full at idle so we shimmed it with 1 large washer. just drilled out the center.
if you have 6-8in/hg vac there is no way the -6psi spring is open at idle...it cracks at -12in/hg.
where do you have your boost/vac referenced?
JDMCRX
06-07-2007 12:31 PM
