can you get a BW with a divided t3 turbine side?
Old Oct 19, 2008 | 12:57 PM
spoolin turbo s's Avatar
Default can you get a BW with a divided t3 turbine side?
and if so what sizes are available
Old Oct 19, 2008 | 01:13 PM
Default Re: can you get a BW with a divided t3 turbine side? (spoolin turbo s)
i found out they do make a .85 divided t3 not sure if they make any other AR's
could one of these divided turbine housing be machined to put the rest of the 35r components in it
that way i could have a divided t3 35r
Old Oct 19, 2008 | 04:16 PM
mrbsponge's Avatar
why would you want to run a 35R instead of an S366? do you already have the 35R or something?
I switched from a 35R to 366 and was blown away, same spool except i picked up about 100+ more hp at the saem boost level
i was using the divided .85AR T3 exhaust side
Old Oct 19, 2008 | 05:16 PM
Default Re: can you get a BW with a divided t3 turbine side? (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">why would you want to run a 35R instead of an S366? do you already have the 35R or something?
i was using the divided .85AR T3 exhaust side</TD></TR></TABLE>
i just don't see how the 366 that can flow alot more than the 35r can spool the same as the 35r
if i go BW it'll probably be a s258 or at most a s362
Old Oct 19, 2008 | 05:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s &raquo;</TD></TR><TR><TD CLASS="quote">
if i go BW it'll probably be a s258 or at most a s362</TD></TR></TABLE>
i would like to see a dyno comparison between the 3 turbo's mentioned above 258 362 and 35r
LU
Feb 22, 2007 10:45 PM
CivicVX94
Dec 6, 2005 07:28 PM
GT61 this 1.8t
Jun 24, 2004 11:02 AM
redboost10
Oct 24, 2003 09:03 AM
BoosterChair
Apr 13, 2003 09:18 PM
