Help 38mm Tial wastegate flange....mounted upside down ?????? is this okay
Old 10-18-2008, 08:08 PM
InTraining124's Avatar
Default Help 38mm Tial wastegate flange....mounted upside down ?????? is this okay
I had my turbo manifold modified for a 38mm tial by welding a Tial flange to a section of shedule 40 then that to the manifold
for anyone that knows what im talking about the tial flanges one side is different...one side has a small cut taken from it....well I left that side facing up to meet the wastegate
Did I mess up ?? will everything be okay ???
I didnt realize at the time that that groove cut out on one side of the flange could be for inserting tubing before its welded so you get a good weld
thanks for the help
Old 10-18-2008, 10:18 PM
Default Re: Help 38mm Tial wastegate flange....mounted upside down ?????? is this okay (InTraining124)
http://cgi.ebay.com/ebaymotors...l1116
you see in that picture that groove cut out of the inside. thats what im talking about
I believe when the manifold was made this groove should be in contact with the tubing on the manifold
and not face up (how mine is) and contacting the wastegate
anyone think I will have a leak issue ???
Old 10-19-2008, 12:43 AM
yakuza's Avatar
I don't see this being a problem, just make sure you use the supplied gaskets to seal between the wastegate and the flange.
Old 10-19-2008, 08:36 AM
I plan on not running any gaskets and having all my surfaces machined flat.
anyone else ????? i could really use some input lol
Old 10-19-2008, 11:12 AM
sooooooo someones gotta have some experience or an answer....i guess ive just gotta wait and make sure my post doesnt end up pages back lol
Old 10-19-2008, 02:18 PM
Ive found a few companys online that sell tial flanges that are like this one
http://turboaddictionparts.com...id=70
they appear to have a smaller sealing surface than my "upside down" flange
any help ?
Old 10-19-2008, 05:15 PM
blinx9900's Avatar
that small lip area is just where you insert the tube so you can weld easier. It should not cause a problem.
Old 10-19-2008, 05:22 PM
CoreyR's Avatar
Default Re: Help 38mm Tial wastegate flange....mounted upside down ?????? is this okay (blinx9900)
the fire ring is what seals and the fire ring is bigger in diameter then the recess in the flange
k9n
02-03-2009 05:09 PM
kabaroo
01-04-2005 01:45 PM
1RMDave
11-16-2004 02:17 PM
f1 vtec
04-29-2004 04:53 AM
NyQuiL
07-15-2003 11:14 PM
Quick Reply: Help 38mm Tial wastegate flange....mounted upside down ?????? is this okay
