Quick vtec question about d16y8
Old Oct 17, 2008 | 07:54 PM
Raven82's Avatar
Default Quick vtec question about d16y8
I'm trying to get a deeper more powerful vtec out of my d16y8 without swapping heads or buying aftermarket cams. Question is can I swap to a better d series cam or is it possible to swap to a different vtec solenoid to get a stronger vtec? What kind of options do I have for doing this?
Old Oct 17, 2008 | 07:56 PM
EJ8_Enthusiast's Avatar
how do you mean "stronger" vtec?
Old Oct 17, 2008 | 08:02 PM
Raven82's Avatar
Default Re: (EJ8_Enthusiast)
I can hardly tell that it hits vtec when it hits at 5500. It doesnt pull like my gsr did when it hit and i cant even hear the sound of the engine change (or cam change) or like my b16. it sucks, i cant tell that it's hitting vtec. I want a stronger pull and to be able to hear it when it hits.
Old Oct 17, 2008 | 08:05 PM
Arent there more factors than RPM?
all my searches say 5500 and that SOHC you wont really hear or feel it.
Modified by EJ8_Enthusiast at 9:10 PM 10/17/2008
Old Oct 17, 2008 | 08:06 PM
Mingo's Avatar
Default Re: (Raven82)
u got an intake on there? u can hear it better with that..i think a y8 is not gonna pull harder on vtec then a gsr
Old Oct 17, 2008 | 08:07 PM
Raven82's Avatar
Okay, you got a sec to explain? I'm retarded when it comes to that lol. Am I taking a shot in the dark or can I eventually get the results I'm looking for?
Old Oct 17, 2008 | 08:11 PM
Raven82's Avatar
Oh, so adding an intake will deepen the sound and let me hear it better? My gsr and civic si already had intakes on them when i bought them so I guess that will help then. So vtec cant be "upgraded" in any way to make it stronger then... it all works the same I'm guessing. vtec is the same whether its an si, gsr, or ex?
Old Oct 17, 2008 | 08:18 PM
Mingo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Raven82 &raquo;</TD></TR><TR><TD CLASS="quote">Oh, so adding an intake will deepen the sound and let me hear it better? My gsr and civic si already had intakes on them when i bought them so I guess that will help then. So vtec cant be "upgraded" in any way to make it stronger then... it all works the same I'm guessing. vtec is the same whether its an si, gsr, or ex?</TD></TR></TABLE>
there was a guy that routed the intake from the engine bay to the passenger window just to hear vtec on his y8..that vid was funny hahaha, but u can really hear the vtec crossover
Old Oct 17, 2008 | 08:19 PM
http://www.metacafe.com/watch/493465/systeme_vtec/
check that out.. I don't see how you could do anything to change how it works to make it more powerful as you put it.
Old Oct 17, 2008 | 08:20 PM
maddheezy's Avatar
turbo it
and no.. it doesn't cost much if you source each part and are somewhat mechanically inclined :D
honestly if you tried you could get a decent hmt w/ name brand parts for &lt;$1000
to answer your question though... yes an intake will make it louder and thats it lol
Old Oct 17, 2008 | 08:25 PM
Raven82's Avatar
Default Re: (maddheezy)
Cool, thanks guys. I know the y8 isn't the greatest head to work with but it's a friend of mine's car and I didnt want to go changing things and [freak]ing it up without knowing the low down lol. I appreciate the insight and that routing the intake to hear it more is quite amusing.
Old Oct 17, 2008 | 10:10 PM
iamthefollower's Avatar
On a single cam u won't feel the vtec like ur wanting.. The reason u felt the vtec come in on ur Gsr and B16 are because of the 2 cams in them..
Old Oct 17, 2008 | 10:43 PM
Shimakid12's Avatar
You will hear it a lot more on a dohc because the vtec cam lobe on the intake of a dohc (b18, b16, etc.) is larger then the vtec lobe on the exhaust cam. This creates that howl you hear when you hit vtec in a dual cam and creates much more power. The sohc vtec lobe is only for the exhaust, and not at all for the intake. When you hit your vtec engagement at 5500 (or whatever it is) the v tec rocker arm is pressurized making the vtec exhaust lobe open the exuast valves a little more. It won't be as loud and won't make as much power as a dual cam for this reason. The exhaust will breathe better when vtec is engaged but it's not giong to create a whole lot of power. The best thing you could do is spend the money and go turbo or do what you said you didn't want to do: after market camshaft, a bigger throttle body with a ported intake mani, a cold air intake, a header and full exhaust, and get the thing chipped out. I've came across a very select few of single cam vtecs that you can actually hear the vtec. Hope some of this info actually helps a bit, if you have any more questions ask.
Modified by Shimakid12 at 10:51 AM 10/18/2008
Old Oct 18, 2008 | 11:26 AM
civic_frank's Avatar
Default Re: Quick vtec question about d16y8 (Raven82)
HA I had a d16y8 in my ex and kinda had the same problem. My Friend did a d15b swap that I could really feel the v-tech in. But I blew mine up.
chai_ek9
Jun 4, 2008 11:09 AM
Sikocivic
22
Jul 31, 2005 02:00 PM
deviant1
Jan 27, 2004 08:56 PM
G3NR8
25
Apr 23, 2003 09:28 AM
willyboyK20
Oct 22, 2001 11:40 AM
