anyone know their stuff about mufflers?
i have a d16y8 with a gutted cat. everything else is stock and i wanna muffler that is very quite at idle/ crusin, but has a little bit of sound (deeper) when you push the pedal down.. nothing loud or annoying. and nothing with a huge tip. just want a clean look and not that annoying raspy sound. and price as well is a concern
i got a magnaflow with 2.25 inch piping on my 99 civic
and it's not too loud it's just fine
i paid 40 bux but it's used
i saw one similar for like 80 bux
I can guarantee anything you put on your car is going to sound like **** with a gutted cat, go buy a new cat (aftermarket), or buy a good used one. Your check engine light will also go away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batallic »</TD></TR><TR><TD CLASS="quote">vibrant muffler</TD></TR></TABLE>
yes, my preferred choice. i have full straight pipe 3" exhaust with that muffler and its pretty quiet. and it looks great
how is a vibrant? i just need a quite one and im worried because my cat is gutted.. on my first car (saturn SC2) i had a thrush and i liked how that sounded.. very quiet at crusin but a clean sound at acceleration
apexi ws2.. you cant go wrong about $500 complete catback with exhaust.. the axel back or muffler alone is like $150??? go to apexi website.. and look up ws2
heard you say thrush. makes me think of what i have. i have a 2 inch inlet and outlet dynomax turbo muffler. just like the thrush. i figure its perfect if it had a small resonator. thats in my setup. as in i have a cat so a small resonator would be ideal. now with no cat i would say a 18-22 inch resonator, turbo muffler and some pipe. looks stock and sounds great!!
ohh. and its cheap to buy.
Often overlooked is the need for a good RESONATOR built into the B pipe in order to remove the raspy crap sound a lot of straight pipe to muffler set-ups have.
You can have a nice muffler, but if you have no resonator in line then it'll still sound like poo-poo.
Obviously the Apex-i catback system will have a resonator built into the b-pipe, but if you get a Vibrant, ES oval, whatever make sure you have a muffler shop weld in a resonator. I know it sounds ghetto but I had a Cherry Bomb welded into my B pipe using it as a resonator and then a quiet muffler that was intended for some old Hemi Dodge on my old 1990 Civic and it sounded awesome. Very quiet, but in higher rpm you knew it wasn't stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">Apexi WS2 is my vote.
Edit: It's got a big tip though.</TD></TR></TABLE>
ditto but i wouldnt really call it a big tip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Often overlooked is the need for a good RESONATOR built into the B pipe in order to remove the raspy crap sound a lot of straight pipe to muffler set-ups have.
Obviously the Apex-i catback system will have a resonator built into the b-pipe, but if you get a Vibrant, ES oval, whatever make sure you have a muffler shop weld in a resonator. I know it sounds ghetto but I had a Cherry Bomb welded into my B pipe using it as a resonator and then a quiet muffler that was intended for some old Hemi Dodge on my old 1990 Civic and it sounded awesome. Very quiet, but in higher rpm you knew it wasn't stock.</TD></TR></TABLE>
agreed i usually run 2 resonators one that comes with the b pipe and a resonator for the test pipe.
89 CRX SI
15
Aug 18, 2005 11:14 PM
Full Race A6
13
Aug 15, 2004 05:20 PM
