Building a "B" series block and have some questions....
Old Jul 28, 2002 | 06:49 PM
DC2_R's Avatar
Default Building a "B" series block and have some questions....
I am going to be building a B16A2 block. Would it make sense to spend the money to get Eagle rods over factory rods, or which should I do? They are close in price, Eagle rods are $365, and the CTR rods from http://www.spwusa.com is $389. I am planning on going the N/A route. TIA
[Modified by JDM_EJ, 8:07 PM 7/28/2002]
Old Jul 28, 2002 | 07:10 PM
FSTASNTZ's Avatar
Default Re: Building a "B" series block and have some questions.... (JDM_EJ)
For that price, I would do the Eagle rods. I actually sold my stock ITR rods so I could get Eagle in my new motor...
Jason
non-VTEC's Avatar
go with eagle rods........but you will need to get aftermarket forged pistons with them.......
Old Jul 29, 2002 | 08:22 PM
dlric's Avatar
if yer going n/a, you can just get arp rod bolts. thats a weak point in the rotating assembly and for the $40 and change u cant beat it. then just have everything balanced (crank, rods, pistons, flywheel, crank pulley, etc).
Old Jul 30, 2002 | 03:24 AM
JDM_DOHC_SiR's Avatar
New User
It might be me but I was under the Impression that the CTR Rod that came in the B16B was longer than the B16A rod..... . . .... . You know since the B16B Block is Based off of a B18c anyways. . Just stick with the Egale rods .. You'll be happy
Old Jul 30, 2002 | 04:05 AM
shermanyang's Avatar
Default Re: Building a "B" series block and have some questions.... (JDM_DOHC_SiR)
yummm...eagle rods...stuffed my motor with four of'em.
Honda_Fanatic
Apr 23, 2008 07:25 AM
Laney
Sep 15, 2004 04:42 PM
slammedcoupe
Jul 18, 2004 06:53 PM
jazz215
Apr 3, 2003 03:39 PM
true
Jan 23, 2003 07:58 PM
