Car made Really wierd noise today.
Old Jul 28, 2002 | 03:44 PM
HXMan's Avatar
Default Car made Really wierd noise today.
It was a loud ticking. I heard it after leaving my house, and immideatly pulled over and turned off the car. I looked and nothing appeared to be hitting anything like accessory belts, etc. Oil was good. I turned the car on again, and the ticking was back. It was a really LOUD ticking, not injector tick. I drove it home, and parked outside. Ticking speed seemed to increase with speed. I revved it up to about 4000 a couple times and then the ticking stopped???
My ideas what it was.
Starter hanging up?
Tranny low on fluid?
It can't be I hope....rod bearing?
Old Jul 28, 2002 | 06:41 PM
D-Man's Avatar
Default Re: Car made Really wierd noise today. (HXMan)
Starter hanging up?<---nope
Tranny low on fluid?<----Nope
It can't be I hope....rod bearing?<----possible
i got a couple more ideas
1 do you have an oil pressure guage,maybe u lost pressure
2 timing belt tensioner..sometimes make noises like that
Old Jul 28, 2002 | 07:18 PM
HXMan's Avatar
Default Re: Car made Really wierd noise today. (D-Man)
Guess it may be time to get an oil pressure guage. Anyone know a place to tap one besides the stock location?
Old Jul 29, 2002 | 04:01 AM
D-Man's Avatar
You could tap it right off the Oil Pump itself...i think Pro-Drive makes such a fitting to screw into the pump,if they dont,somebody does cause i saw it,I'm just not 100% sure i got the right vender
Old Jul 29, 2002 | 04:28 AM
DSF's Avatar
DSF
Valve tap...? Use a screwdriver against your ear (like a stethoscope, or an actual stethoscope if you have one) to localize the sound.
Old Jul 29, 2002 | 12:55 PM
HXMan's Avatar
I think it is the starter hitting the flywheel. I am going to open up the inspection plate today.
OG pato
Aug 21, 2018 12:53 PM
b20ricepower
Dec 16, 2013 07:44 AM
solroute
Apr 27, 2005 10:10 PM
SkoundrelUSA
10
Mar 3, 2005 01:10 PM
jazz215
Nov 22, 2004 10:29 PM
