rod knock or?? tick sound
http://www.youtube.com/watch?v=xHvx9CjAR9Q. i bought this car for $200 it sounds like something knocking inside, i cant tell if its comming from the head or block, wondering if anyone knows if this is my rods knocking or is it comming from the head?
It's tough to say... try a valve adjustment first, it's cheap and fairly easy to do. If you don't know what you're doing, don't attempt it yourself. You can probably get one done for like 75$ or something like that. If that doesn't fix your problem, time for a rebuild.
i see...the guy i bought it from said oil was spilling out from the bottom when it happend. does this mean it has to do something with the block? ill try an get a valve adjustment just to see if it'll work
Well with that in mind, I don't think a valve adjustment is the answer... check to see if you can find any major oil leaks... because this is sounding worse than I thought.
accord2civic2prelude
19
Feb 24, 2010 05:57 AM
