Blow Off Staying open @ Idle!
Old Jul 28, 2002 | 06:45 AM
forcedaccord95's Avatar
Default Blow Off Staying open @ Idle!
I have a blitz blow off vavle and it is staying open about a quarter of the way at idle. when given gas, it stays close and lets no air out like it should. the reason I ask is because, the adjustment screw on the top is really easy to turn. I thought it was suposed to be spring loaded! Is this right?
[Modified by forcedaccord95, 3:45 PM 7/28/2002]
Old Jul 28, 2002 | 06:56 AM
94turboteg2's Avatar
New User
Default Re: Blow Off Staying open @ Idle! (forcedaccord95)
I have an HKS BOV, does the same thing, closes when no vac present. I believe this is normal operation on most BOV's. I put a filter on mine because of this.
Old Jul 28, 2002 | 07:04 AM
JM Performance's Avatar
Default Re: Blow Off Staying open @ Idle! (94turboteg2)
sounds right.
also, calm down. if you get all worried about every little thing on your car you'll go nuts!
Old Jul 28, 2002 | 08:31 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
haha! man i told you it'll do that...it wasn't doing that and that's why i took your **** apart and fixed it. it's blowing off still right? and...before i touched it, it wouldn't. when you throttle, it'll slam shut. when you close the throttle, put your eye over the blitz horn and look deep into the unit and you'll know if it's working j/k don't do that.
Old Jul 28, 2002 | 06:13 PM
Default Re: Blow Off Staying open @ Idle! (not so civic)
nice picture tool!
SpoolnByYou
Jan 26, 2006 11:40 AM
igo4bmx
Apr 12, 2005 04:45 AM
TurboTegB18c
Sep 12, 2004 10:58 AM
EFbomb
Sep 3, 2004 01:08 PM
_Endless_
Jul 4, 2003 10:56 AM
