Helping a buddy diagnose his problem: spark plug flew out, dented hood, spark plug wire is toast
Old Oct 7, 2008 | 07:18 AM
DarkBB4's Avatar
Default Helping a buddy diagnose his problem: spark plug flew out, dented hood, spark plug wire is toast
I've been working on hondas for about 6 years now and i've never seen anything like this. 96-98 Civic nonvtec, im guessing 100K+ milege. My friend said he was driving the car, heard a pop and shut it off. there is a dent on the hood, the spark plug wire is destroyed and there is no sign of a sparkplug anywhere! My question is...
Is it IN the motor? or did it fly out??
[IMG][/IMG]
Old Oct 7, 2008 | 07:25 AM
davefromPA's Avatar
Default Re: Helping a buddy diagnose his problem: spark plug flew out, dented hood, spark plug wire is toast
what does the dent look like and is it directly over that plug hole? considered taking the head off to look? a stick magnent might be a good choice cause it can reach in and collect any debris from the cylinder if there is any.
Old Oct 7, 2008 | 07:35 AM
DarkBB4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davefromPA &raquo;</TD></TR><TR><TD CLASS="quote">what does the dent look like and is it directly over that plug hole? considered taking the head off to look? a stick magnent might be a good choice cause it can reach in and collect any debris from the cylinder if there is any.</TD></TR></TABLE>
yea the dent looks to be as if a small object (spark plug) hit it.. right over the cylinder.... Im trying to avoid taking the head off, and ill try the magnet thing.
thanks
Old Oct 7, 2008 | 08:06 AM
davefromPA's Avatar
did you look down the hole with a flashlight to see if there is any sparkplug left?
Old Oct 7, 2008 | 08:45 AM
B16AGUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davefromPA &raquo;</TD></TR><TR><TD CLASS="quote">did you look down the hole with a flashlight to see if there is any sparkplug left?</TD></TR></TABLE>
X2 I sure hope that it blew out clean...getting the head removed and then boring out the hole to remove residual threaded pieces sucks!
Old Oct 7, 2008 | 10:23 AM
HeikDiesel's Avatar
If it blew the plug out, more than likely the aluminum threads of the head are gone. Time to pull the head
Old Oct 7, 2008 | 11:33 AM
DarkBB4's Avatar
im going over there again today to do some more analysis
situation 1:
Plug backed out and threads are fine. new spark plugs and wires all around : 75$
situation 2:
Plug shot out, ruining all threads, NEW head + headgasket: 250-500$
situation 3:
Plug dropped down, scarring cylinder walls and ruining bottom end: 500-1000$
Old Oct 7, 2008 | 12:06 PM
HeikDiesel's Avatar
I highly doubt number three, but if it blew that plug out you have serious problems with that engine. Something was in that cylinder on compression to blow that thing out (coolant, sucked water, etc). I'd be checkin rods if that is the case
Old Oct 7, 2008 | 12:09 PM
Hanmin's Avatar
I think heikdiesel is on the right track. keep us updated, I want to see what the problem was.
Old Oct 7, 2008 | 12:18 PM
jdmturbo1127's Avatar
Default Re: (Hanmin)
Same thing happened to me last summer. I found out that the spark plug just wasnt tight! I never found the plug, but I just checked down in the cylinder, threw a new one in and it was good to go!
Old Oct 7, 2008 | 01:05 PM
D16SiHatch's Avatar
Default Re: (jdmturbo1127)
put a flashlight down there already lol, i'm curious how this will turn out.
Old Oct 7, 2008 | 01:59 PM
EH3USDM's Avatar
I bet someone just forgot to tighten that spark plug.
Old Oct 7, 2008 | 04:34 PM
DarkBB4's Avatar
Default Re: (EH3USDM)
the thing is, is that he told me he hasnt changed those in a while! I looked in the hole w/ a light earlier, and found no remenance of anything in there... there was carbon deposits on the under side of the hood, and a sharp dent there also...
ill keep everyone posted...
Old Oct 8, 2008 | 10:22 AM
B16AGUY's Avatar
Default Re: (DarkBB4)
The suspense is killing me!
How are the threads in the head?
Are they still present...Man if they are ok, your friend is one lucky guy.
Old Oct 10, 2008 | 03:53 AM
DarkBB4's Avatar
Default Re: (B16AGUY)
put new spark plugs and wires on, and now the car does not even start... WTF!?!!?!?
im gonna get my compression tester at home, because we are getting spark and fuel.. wtf!
Old Oct 10, 2008 | 04:39 AM
davefromPA's Avatar
keep us posted.
Old Oct 10, 2008 | 05:19 AM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">put new spark plugs and wires on, and now the car does not even start... WTF!?!!?!?
im gonna get my compression tester at home, because we are getting spark and fuel.. wtf!</TD></TR></TABLE>
I see this going bad places
Old Oct 10, 2008 | 05:35 AM
instrument's Avatar
um, who's gonna pay 500-1000 for a non vtec sohc block?
i paid 1200 for my entire car.
Old Oct 10, 2008 | 10:33 PM
MoreBoost!'s Avatar
Default Re: (instrument)
that sucks
Old Oct 12, 2008 | 05:44 PM
DarkBB4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">Plug dropped down, scarring cylinder walls and ruining bottom end: 500-1000$
i paid 1200 for my entire car.</TD></TR></TABLE>
Hey, go get an estimate for a new rebuilt bottom end from a decent shop... at the very least, they will charge you 500$
anyways, they regapped the sparkplugs and gave it gas and it started right up!!!
horraahhh
thanks guys!
Old Oct 14, 2008 | 11:34 PM
Hanmin's Avatar
so the threads weren't damaged? ever find the problem? maybe the spark plug screwed itself out over time and then boom? so only half the threads are gone? iunno. weird
BuiltCivic99
May 2, 2009 06:49 AM
seriot
Apr 2, 2008 11:46 AM
Lokisdope
Oct 5, 2007 08:33 PM
Jasz
Jun 26, 2005 08:13 AM
Mr Synister
Jun 6, 2005 06:50 PM
