need Help doing the resistor fix for the O2 CEL???
Old Oct 2, 2008 | 07:30 PM
Turbo O's Avatar
Default need Help doing the resistor fix for the O2 CEL???
Im trying to get rid of my CEL, code 1.
I've read of the resistor fix and tryed it myself but it didnt work for me so I wanted to see if I was doing something wrong. From what I read I just have to cut the wire at Pin A25 which is for the O2 Heater Power, then cut the wire at Pin A6 which is the O2 Heater GND and solder in a 20ohm 10watt resistor. Is this correct or is there more to it?
Old Oct 3, 2008 | 11:00 AM
Relic1's Avatar
that may work if you have CEL41. (O2 heater)
CEL1 means you're O2 sensor signal is bad. Replace the O2.
Old Oct 6, 2008 | 08:50 AM
Turbo O's Avatar
Default Re: (Relic1)
I have both codes it switches from cel1 to cel41.
I've tried a new O2 and still have the code.
Im thinkin it could be the wiring. What kind of readings should I get when testing with a voltmeter?
Old Oct 6, 2008 | 08:57 AM
HRTuning's Avatar
Default Re: (Turbo O)
0-1v on the signal wire with the car running.
Old Oct 6, 2008 | 03:26 PM
Turbo O's Avatar
So has anyone actually tried this resistor trick and had it work for them?
Boston_George
11
Dec 20, 2004 07:55 AM
Mini-mEK4
May 10, 2004 11:05 PM
Aphrodavid
Dec 15, 2002 04:50 PM
Casey
Sep 29, 2002 06:15 PM
