weird problem
ok so i swapped a 96 vtec head on my 00 y8 block
when i try to start it, the revs are real high, prolly like 3000 and loud.
i did a compression check and it says 180 180 180 150
so that means bad headgasket? because i just changed it when i installed the head
could it be i messed up with some hoses?
and also i gain MPH, maybe its because my front left tire is off and the car is on jacks?
high rpm doesnt mean your headgasket is toast. overheating, disappearing coolant, and/or a oil pan full of choco milkshake would tell you that. sounds like you have a massive vaccum leak. did you use a new intake manifold gasket and clean off the mating surfaces. check all your vaccum lines and ports. and make sure your tb isnt somehow being pulled partially open
could it be i didnt get one of the nuts on? in the center of the intake manifold there is one underneath that i couldnt get it on.
i used gasket spray on the old intake manifold so that should work right?
so would a vacuum leak cause the compression to be 180 180 180 150?
are the valves shutting all the way or are the valves on the 150 cyl. to tight. that can cause a bad compression test. as far as the high idle check to make sure no intake gasket leaks or that the iacv is clean and working right.
you could take your intake off entirely and you would still have the same compression results.
When you say you used gasket sealer, does that mean you still had the original gasket on there and it was in salvageable shape so you simply sprayed some sealent on that? or that you had no gasket oncesoever and just used the spray? if so i'd definately be willing to bet thats where you're getting your leak from. even if you sprayed down a used old gasket though, the results are sketchy at best. and like the other guy said you may also be leaking through your iacv. if the idle is steady at around 3000rpm though and not surging up and down, then that would rule out the iacv.
i dont know if the valves are too tight i got the head from a person on this site.
the iacv is good. i cleaned it out im just stuck now. idk what to do...
prolly redrain my coolant, clean the intake mani mating surfaces off, clean the intake mani gasket
crap, what would happen if i used the D16y7 intake gasket? i think i mgiht have accidently done that
im going to go drain the coolant and remove the intake mani and check...ill be back in 20
also in responce to the headgasket...
it was a brand new felpro headgasket and i sprayed the copper spray onto it
i also sprayed that stuff on a reused intake mani gaskety too
AND WHY NO NEW INTAKE GASKET. the old gasket has been squeezed and now re-tightened that might be the vacuum leak.
replacing the intake gasket is cheap insurance when re-installing it
well i need to get a new intake manifold gasket, as the one on the old y8 head ripped as i was taking it off. and i figured i was using teh y7 intake gasket on it.... i didnt get a new one because i dont have any money. but ill have some tomorrow i hope
..... i also noticed a tapping noise when it was idling at 3000rpms
1) new gasket
2) adjust valves to spec
3) check the trottle body and clean it
4) re-set the ecu ( remove battery cables for a few minutes and re-connect)
5) let the car idle for 15 min don't touch throttle so the ecu will re-lear
hope you get it fixed let us know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote">well i need to get a new intake manifold gasket, as the one on the old y8 head ripped as i was taking it off. and i figured i was using teh y7 intake gasket on it.... i didnt get a new one because i dont have any money. but ill have some tomorrow i hope
..... i also noticed a tapping noise when it was idling at 3000rpms</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote">ok so i swapped a 96 vtec head on my 00 y8 block
and also i gain MPH, maybe its because my front left tire is off and the car is on jacks?</TD></TR></TABLE>
hold up... so you've got a y8 block, a y8 head, and a y7 intake manifold?
..... i also noticed a tapping noise when it was idling at 3000rpms</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebleek »</TD></TR><TR><TD CLASS="quote">ok so i swapped a 96 vtec head on my 00 y8 block
Slo96ex
Mar 2, 2006 08:38 PM
