Transmission & Drivetrain Gearboxes, Differentials, Clutches
gsr tranny problem
Old Sep 29, 2008 | 01:57 PM
iheartmygsr's Avatar
Default gsr tranny problem
When im driving lower rpm's it aint as bad but whenever its in high rpm's the transmission does not like to shift into gear, when upshifting i hit the clutch and when i go to put it in gear i have to hold it until the rpms drop then it go's in, when downshifting i have to push it in and rev it until it matches then go's into gear. any suggestions on what the problem could be? thank you for any help
Old Sep 29, 2008 | 02:17 PM
unusual71's Avatar
you forgot to tell us how many miles on the transmission and clutch. could be the clutch not releasing all the way, or if the clutch is ok its probably worn out trans parts
Old Sep 29, 2008 | 03:53 PM
Default Re: (unusual71)
133k but it was owned by old people so it wasnt beat on i had a tech drive it he said that it could be the clutch not releasing as well i figured that id ask on here for some extra suggestions
PrettyFastRide
13
Jul 13, 2006 06:30 AM
lshatchcx18
Jun 14, 2004 12:46 AM
elips0id
Apr 1, 2004 03:38 PM
ar5enal
Apr 27, 2003 06:44 PM
Jmm0056
Sep 12, 2001 01:54 PM
