need input
Old Sep 28, 2008 | 11:45 PM
92GSR HB's Avatar
Default need input
So coming home the other day my clutch sank to the floor etc, managed to get it to krogers. Noticed fluid coming from my slave cylinder it looked like. So today a friend helped me and swapped my old slave cylinder from other hatch onto my car. When we were bleeding the system clutch pedal never got any feel back into and never could get it to bleed without air coming out. We seriously bleed it over and over never could get all the air it seems. What would cause that and y cant we get the air out? Any suggestions on what could be wrong or something we miss? Im clueless and i need to get it fixed tomorrow cuz its stranded there. Any input or help would be appreciated
Old Sep 29, 2008 | 06:16 AM
hatchling37's Avatar
Default Re: need input (92GSR HB)
You have a loose line at the master? Make sure all your lines are tight. Make sure you don't have a leak around your master cylinder.
Old Sep 29, 2008 | 08:58 AM
Ryan#1's Avatar
Default Re: need input (hatchling37)
You should check that the clutch fork is in one piece still, if it breaks it will hyperextend the slave (causing it to blow apart and leak) and if it's not actually working the clutch there would be no feel in the pedal.
Old Sep 29, 2008 | 01:36 PM
92GSR HB's Avatar
quick update, did some further bleeding of the slave cylinder using several methods and no luck. Still gettin air in the system somewhere, so i guess im goin to replace the master cylinder and go from there. Thanks for all the info so far, and ill keep tryin. Thanks
Jdmfeen34
May 15, 2017 05:38 AM
niceprelude
33
Dec 20, 2008 04:56 AM
garyc17
Dec 8, 2006 09:58 PM
civiceg500
18
Aug 16, 2004 06:11 PM
