TPS Adjustment Problem - 0v/3.3v
Old Sep 23, 2008 | 11:32 AM
Jonathan_ED3's Avatar
Default TPS Adjustment Problem - 0v/3.3v
I've got a problem adjusting my new (from streetimports https://honda-tech.com/zerothread?id=2014912) TPS on a d16z6.
According to the FSM, at throttle closed it should be registering .5V, and at WOT it should be registering ~ 4.5V.
No matter which extreme (or any variation in between) I turn the TPS, it always and only registers 0V at throttle close, and a max of 3.3V at WOT. Tried two different Fluke MM, and two different stock P28 ECU's.
Battery voltage is 12.5, and when I test yellow/white against green/white at TPS harness, voltage is exactly 5V.
Anybody have any suggestions? I need to get rid of this TPS code!
Modified by Jonathan_ED3 at 3:01 PM 9/23/2008
Old Sep 23, 2008 | 11:54 AM
obuhmyuh's Avatar
Default Re: TPS Adjustment Problem - 0v/3.3v (Jonathan_ED3)
sounds like your TPS is garbage, are you sure you calibrated it correctly?
Old Sep 23, 2008 | 12:01 PM
That's what I'm trying to do - I'm trying to set it to the factory spec, but it seems there isn't enough adjustment allowance to get it set to .5v/4.5v.
Old Sep 23, 2008 | 12:24 PM
obuhmyuh's Avatar
Default Re: (Jonathan_ED3)
by loosening the screws and and rotating it slightly? If your still not getting the right specs then i would say its your TPS or its ECU related.
Old Sep 23, 2008 | 12:38 PM
Default Re: (obuhmyuh)
Yes, I'm trying to rotate it clockwise or counter clockwise and set it at .5v/4.5v WOT, but it won't hit those readings in any direction or at any stop in between those.
I've tried two different ECU's, so I can only guess that the brand new TPS is bad - which is hard to believe!
Old Sep 23, 2008 | 01:14 PM
obuhmyuh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I'm trying to rotate it clockwise or counter clockwise and set it at .5v/4.5v WOT, but it won't hit those readings in any direction or at any stop in between those.
I've tried two different ECU's, so I can only guess that the brand new TPS is bad - which is hard to believe!</TD></TR></TABLE>
not really, i've ordered some that weren't working properly when the arrived, they're some-what sensitive.
Old Sep 23, 2008 | 02:36 PM
JDM EJ2's Avatar
I know Honda calls for it to be at .5V but I ordered one from Inline4 and I adjusted mine to .3V and its much better. Give that a try and let us know how that goes for you...
Old Sep 23, 2008 | 04:10 PM
I can't get it to register ANYTHING other than 0.00v at closed throttle.
It always registers only 0.00V closed. Not sure what else to do but buy another TPS
Old Sep 23, 2008 | 04:58 PM
geebs's Avatar
That TPS is toast. the ECU is sending the 5 volts.. so that rules out the ECU.
Are you measuring the voltage at the TPS sensor or the ECU?
If you're testing at the ECU maybe you have a bad wire?
Old Sep 23, 2008 | 05:06 PM
I'm testing at both the ECU and also at the sensor itself.
Something I'm thinking about trying is enlarging the holes on the TPS and seeing if I can get it within spec.
As far as I know, you have to set the WOT before you can set the closed throttle. If I can get the WOT dialed in after enlarging the holes, maybe I can get the closed throttle set properly.
I knew I should have just bought a used OEM TPS instead of going for a "new" chinese made product.
Old Sep 23, 2008 | 05:55 PM
geebs's Avatar
I used an old OEM TPS for my crx/b16 when i had idling issues..
I just slapped it in there.. and moved it around till i had 0.5 volts at idle
It could possibly be the TPS..
Old Sep 23, 2008 | 05:57 PM
geebs's Avatar
Default Re: (geebs)
I actually might have one laying around if you want it..
just pay a few bucks for shipping and its yours..
Old Sep 24, 2008 | 09:56 AM
Default Re: (geebs)
I took off and reinstalled the TPS. I think the first time around I didn't have the arm lined up.
I got it adjusted just fine, although to get the closed throttle to hit the .5V that the service manual calls for, I had to slightly adjust the throttle plate stop screw.
NEEDBOUTTREE5O
Feb 10, 2012 02:42 PM
mouab18c1
Engine Management and Tuning
18
Jun 3, 2010 10:57 AM
Devious951
Sep 18, 2009 05:11 PM
Jonathan_ED3
Sep 24, 2008 09:55 AM
h2bv8killa
Aug 16, 2007 02:14 AM
