Stalling
Old Sep 18, 2008 | 11:59 AM
corince06's Avatar
Default Stalling
i have a 92 civic si with a 95 gsr swap...the engine is totally rebuilt for boost except the camshafts...when i pull up to a stop light or stop sign and put my car in neutral it idles really low and fluxuates sometimes so bad it stalls...i was wondering what could be causing this to happen...thank you
Old Sep 18, 2008 | 12:00 PM
Hanmin's Avatar
did you change the injectors??? is it tuned?
Old Sep 19, 2008 | 07:26 AM
corince06's Avatar
Default Re: (Hanmin)
yes and yes...i got it tuned a few weeks ago
Old Sep 19, 2008 | 07:31 AM
Jonnyb5's Avatar
Well theres always the 2 basics. Air and fuel. Check if your throwing any codes from the ECU. I would then trail threw the ignition system and see if anything is loose. Maybe your distrubtor cap is toast. Also pull the hotwires 1 at a time to see if every piston is getting spark. Make sure your timing is good and your spark plug gaps are correct. Remember its just a game of air and fuel.
Old Sep 19, 2008 | 07:37 AM
psychotic7's Avatar
IACV could also be a problem....have you ever cleaned it???
Old Sep 19, 2008 | 11:21 AM
ek4_b16a's Avatar
Default Re: (psychotic7)
^^what he said...is the clip busted on it that is causing it to loosen up? check that also...gl
Old Sep 19, 2008 | 05:42 PM
corince06's Avatar
Default Re: (ek4_b16a)
thank you guys
Old Sep 19, 2008 | 06:10 PM
DSMkiller123's Avatar
its an ecu problem
Old Sep 24, 2008 | 05:20 AM
chickenwing's Avatar
Default Re: (DSMkiller123)
I have a similar problem as well.
I have a Y8 with stock ECU.
new cap, new rotor, new plugs, new fuel filter.
JUN1OR
Oct 18, 2021 09:16 PM
Robin1955
Engine Management and Tuning
Nov 9, 2013 06:59 AM
thanh4o8
Dec 10, 2009 11:28 AM
egGSR_hi
May 16, 2009 12:23 PM
Trbospnkr
Jan 3, 2004 06:16 AM
