Stalling
Stalling
i have a 92 civic si with a 95 gsr swap...the engine is totally rebuilt for boost except the camshafts...when i pull up to a stop light or stop sign and put my car in neutral it idles really low and fluxuates sometimes so bad it stalls...i was wondering what could be causing this to happen...thank you
Well theres always the 2 basics. Air and fuel. Check if your throwing any codes from the ECU. I would then trail threw the ignition system and see if anything is loose. Maybe your distrubtor cap is toast. Also pull the hotwires 1 at a time to see if every piston is getting spark. Make sure your timing is good and your spark plug gaps are correct. Remember its just a game of air and fuel.
egGSR_hi
05-16-2009 12:23 PM
Trbospnkr
01-03-2004 06:16 AM
