Car died, no spark, no CEL. s300 installed.
Been troubleshooting this problem for a week. I rarely ask for help, but I'm stumped here.
91 CRX, 94 USDM b18c1, P06 ECU w/ Hondata s300 (now P72 ECU w/ s300).
I was driving the other day and car suddenly died on 3/4 load at about 4000 rpm, cold engine. No spark, no fuel, check engine light wouldn't even turn off when I turn the ignition to II. No fuel pump priming, nothing. I couldn't even connect to the ecu via Smanager anymore. OK dead ECU is most likely the problem. (previous guy installed the ECU replacement power supply capacitor terribly - too much heat, melted traces. I suspect it finally went)
I had a spare P72 GSR ECU around so I soldered in the pins, transistors, jumpers, etc, put the ECU in the car and voila, no check engine light and I can finally hear the fuel pump prime (didn't before). Upload my .cal, datalog record, try to start and no spark.
Pulled a plug out and checked spark, fail
Per factory manual and/or helmes, I tested and/or replaced:
- Tested coil, ok
- Tried replacement coil, no change
- Tested ignitor, ok
- Tried replacement ignitor, no change
- Tested main relay, ok
- Inspected and tested critical fuses underhood and dash, ok
- Pulled an injector harness off and hooked it up to a spare injector, clicked in my hand on startup, ok
- Bought and installed junkyard distributor, ok
- Cleaned ground on thermostat, ok
- Placed jumper wire from negative battery to a distributor leg, no change
- Tested ignition switch, ok
- The disti is spinning while cranking, no I don't have a broken timing belt.
What's weird is that now the check engine light doesn't come on at all, not even when I turn the ignition on! I did assign an aux input on the S300 to SCS, service connector switch, but I don't think it is related, as this was done years ago.
What am I missing? Bad install of S300 done by me? I'm decent at soldering, but who knows. I welcome all thoughts. Hondata sManager datalog (of engine cranking) and calabration attached.
Thanks in advance,
Mike
- Tested coil, ok
Thanks in advance,
Mike
Re: Car died, no spark, no CEL. s300 installed.
Anyway...
Perhaps I need a new ECU. I just don't have any other reason for no spark - and no check engine light with ignition. It normally turns on with ignition and shuts off 2 seconds later.
I even took the P72 out and re-touched up the solder points needed for s300 install.
Mike
it seems youre in the right track, my suggestion for u is to get a stock ecu and try it without installing the s300.
Hi I think got the same issue my car was in idle and out the no where just die it just crank but no fuel pump working I check everything the only thing I think it's the ecu is a hondata s300 v3 did you replace the whole ecu or find a virgin ecu and install the s300 on the new ecu?
Take the ECU cover off and take a look for leaky or blown capacitors. Send a picture here in this thread or PM.
jun1or
91stocksi
53
10-19-2012 05:56 PM
EdSales
03-23-2010 09:41 AM
